Question about putting LS1 Brakes on LT1
I have asked before but I couldnt get a straight answer so I am gonna try again cause I am almost ready to start putting everything together...
I have an 8.8 pumpkin and am using my 10-bolt tubes to builg my new rear end. I will also be using Moser hardened axles with GM bolt patterns...
I have the rear brakes off of an LS1 that I am going to install on here and I needto make sure I have everything to complete the conversion. I have been told something about brake lines but noone told me exactly what I needed so here is what I have:
LS1 Calipers
LS1 Caliper Brackets
LS1 Backing Plates w/LS1 E-Brake Assemblies
LS1 E-Brake Cables
LS1 Rotors (dont worry about these, I'm buying cross drilled/slotted rotors)
All Hardwear off the LS1
What else do I need to install these? I have been told C5 Brake Lines but will this kit from Summit do both fronts and back for 99.95 or do I need more lines, or what? Cause I am converting the fronts to LS1 at the same time...
http://www.summitracing.com/parts/RUS-692190/
Thanks for the info in advance guys and gals!
LS1 Calipers
LS1 E-Brake Cables
