Track Results
Track Results
I just got home from the track. DA 2986....80 degrees, 89% humidity.
Right off the trailer first pass ever with this combo this was the best pass of the night:
1.629 60 ft
4.775 330ft
7.446 1/8th
91.80 mph
The track started sweating (from a rain earlier today) and became pretty worthless
The rest of the Night I ran consistant 7.50s with a high 1.7 60 ft. I couldnt get the car to hook for anything was was spining through 1st and part of 2nd most passes.
These were on 26x10.5/15 hoosier qtp tires with 12psi on a 10"wide draglite. Any thing higher I was blowing through 1st and 2nd.
I know there's more left in this setup. The car has 100% stock suspension and even has the front sway bar. Can someone point me in the right direction to get this thing to hook up?
I was thinking:
LCA relocation brackets
comp 3 way adj shocks
boxed lower control arm
I have an adj. BMR Torque arm thats not installed as well.
My mph seems kinda low, I need to figure converter slip. I was going through the traps at about 5600-5800 rpm around 92mph
1.629 60 ft
4.775 330ft
7.446 1/8th
91.80 mph
I was thinking:
Pinion angle is -1.5.
I know the mph is low, I actually just checked the converter slip on all my slips.....It varried from 22-26%. I think Ill have to make a call monday. It should be 7-10%. Im not sure how much that will improve my mph and time. But hopefully Ill see something from it.
Speed demon, I made 388 rwhp and 381 rwtq Unlocked. We were fighting some converter problems on the dyno as well
You should be able to get your 60' in the 1.5's easy with some suspension work. Lose the front swaybar first, install the aftermarket torquearm@-(2-3)degrees, add an airbag in the right rear spring and get some more passes on it. I don't think you should have a problem running 96-98mph once everything is lined out. When my car used to run 7.40's in the 1/8th , that came out to 11.60's in the 1/4mile and with those high DA's you had that isn't too bad for the first time out. Goodluck
keeps the passenger side from squatting as much, from the torque...
basicly stiffens the suspesion so it stabs the rearend it to the ground intead of the spring absorbing the energy.
LS1TECH Sponsor
pull the front sway bar and leave from a dead idle. Should see some 1.58-1.60 60 fts. Some drag shocks will help too. Set the rear on the stiffest settings.
Not bad for the being in the heat. I would look into the trans/converter slipping and see why there is 20-24% slippage. Anything over 10% is BAD and gonna kill ET and MPH.
The 7.44 and 92 match up pretty well but if the trans/converter is slipping that much, it might "only" run that ET because the converter is slipping and causing that MPH.
If you remove the front sway bar and go back to the track in 3 months with no other changes . . it will be at least 2 tenths and 2 MPH faster due to teh cooler weather. Not that I would go back with no changes but the heat really effects things and the car will not run its fastest pass the first time at the track or in this heat.
First thing to address will be the converter/trans slippage and see what is up with that.
You could swap in a 6 speed and pick up 3-5 MPH but run 5-6 tenths slower. An auto trans car will always trap lower MPH than a 6 speed car. Some 6 speed cars will 60 ft well but the average car with average mods and average driver will be getting a 1.800-2.00 60 ft compared the the average A-4/3600 stall car that will 60 ft in the 1.50-1.65 range.
I love how people claim auto's are killing their mph by huge amounts to justify their track times. Auto's don't hurt 1/8th traps nearly as much as they hurt 1/4 trap speeds. I did a t56 swap in my car and I only gained 3mph in the 1/4 over my slipping 4l60e that was hitting the limiter before shifts and shifting well past where my cam was getting valve float. If the tranny wasn't slipping I'm sure it would have been a very marginal gain in mph if any at all. A claim of picking up 3-5mph in the 1/8th with a simple tranny swap is laughable.
Village Troll
My car is far from set up for the track. One setup with the LPE heads and 211 cam, stock torque arm, Hotchkis LCA's/relocation brackets, 4.10 gears on BFG Drag radials it was able to produce 1.70 60' times. After putting in the 3.73 gears it was in the 1.75 range. Anyone who races on a well prepped track with a good tire and can't get less than a 1.8 60' w/ heads/cam/M6/gears to complement setup is doing it wrong. I reckon if what is listed is too elaborate then "average" needs to be defined.
i have the exact same came, in a 11.7 396 and i put down 410 rwhp and only 347 rwtq unlocked, how is that possible? lol
nice times though man, thats pretty bad slip you should be at like 95 mph when its sorted out
