LT1 Oil Pressure Problem
So I just bought a 94 TA with the LT1 motor and I think it might need an oil sending unit. When I first start it, the oil pressure is fine: it runs about 50 to 60 psi consistently. After it warms up though, it drops down to around 18 to 20 psi at idle. Has anyone else had this problem? Is it even a problem? The tech at the dealership told me that it was fine, but if it got any lower that it needed to be diagnosed and fixed.
thats about the same as mine, it starts out at about 50-60lbs cold, after it warms up its a little over 20, and when i rev it up it goes up to about 50.. engine has about 67k miles on it..
Alright, guess i don't have anything to worry about then. I was just on edge about it a lil bit because my 85 has a 5.0 liter TPI and it consistently runs 40 psi at idle, even when it warms up. Thanks Guys!
