pistons/compression
Old 08-01-2010, 03:04 PM
slomarao's Avatar
Default pistons/compression
Building a 357 currently, have a few ?'s
Heres the build basic's
2 bolt main
Stock crank
Stock rods, ARP bolts
Forged pistons, 40 over
ARP head bolts
Melling 10554 Oil pump
LE 226/234 stick
Light ported heads/intake (322rwhp w/all boltons, no EWP/Lid, mac headers)
52mmtb/30 lb inj/3.73's/lid
Boltons
I want to find a cheaper forged piston since I will be running stock rods, 2 bolt, stock crank. I dont really want to have a weak link in the bottom end and spoke with the machine shop owner for a bit. He thinks I should use Mahle, but I wanted to see what you guys thought about speedpro, SRP, etc.
The car will see a 150 hit the following year. I may get N20 rings for whatever cheaper piston I get... Just a thought tho, looking for some input?
Next the car will be a DD April to Sept but I want to run all the compression I can. How much do you think I can get away with on DCR/SCR??
I dont want to go above 12.1 tho. It will only get pump gas, 93 in chicago tho so its not too bad.
Any help would be appreciated.
Old 08-01-2010, 03:15 PM
kierstyn's Avatar
For a cheap piston speedpro will do the trick at the nitrous level you plan on using.
Old 08-01-2010, 04:16 PM
slomarao's Avatar
well i will probably end working my way up to a 175, and prolly 200 also.
Old 08-01-2010, 04:56 PM
brucer's Avatar
i would doubt the rods, before i would the speedpro pistons..
Old 08-01-2010, 05:01 PM
slomarao's Avatar
I know there is no ? that the rods will be the weakest link but should I maybe consider a hyper piston?
What about compression?
Old 08-01-2010, 07:28 PM
RamAir95TA's Avatar
Forged Mahle pistons would be a good choice. Maybe go with a forged Compstar rod as well. If it's all apart, you might as well find the coin to eliminate any potential weak links.
Old 08-01-2010, 09:14 PM
slomarao's Avatar
**** I would be happy with scat I beams. My budget is about 1200 more than i planned and I just found out the clutch I have isnt going to last so thats another 450.
Old 08-01-2010, 09:17 PM
RamAir95TA's Avatar
Go for it!
http://www.summitracing.com/parts/SCA-25700716/
Old 08-01-2010, 09:25 PM
slomarao's Avatar
if i do make a move on the rods should i go 6 inch?
Old 08-01-2010, 09:31 PM
RamAir95TA's Avatar
For a mild street motor, I don't think it will really matter to be honest. Lots of guys swear by the 6", some swear by the 5.7"s.
If it were me though, I'd go with the 6".
Old 08-01-2010, 09:45 PM
slomarao's Avatar
Yeah but than my 2 bolt main is my weak link. If i get rods I may as well do a 4 bolt or at least stud the mains....
Never ******* ends....
Old 08-01-2010, 09:48 PM
RamAir95TA's Avatar
No way. The stock 2-bolts are plenty strong. The only reason I went with a 4-bolt block is because I got a good deal on it - otherwise I would have stuck with the 2-bolt. You're fine with the 2-bolt, especially at your power level. Don't sweat it.
Old 08-01-2010, 10:03 PM
slomarao's Avatar
Alright you talked me into it. It will also allow for me to run the 200 safely, well kind of.
What about my DCR/SCR??
Old 08-01-2010, 10:06 PM
RamAir95TA's Avatar
I think 12.0 static is a good number to shoot for. With that cam your DCR will probably be around 8.4 - 8.8, plenty good for a street motor.
Old 08-01-2010, 10:32 PM
slomarao's Avatar
12.0 for S-comp? Dont you think I will have some tuning issues? it will be a 6month DD.
Old 08-01-2010, 10:36 PM
RamAir95TA's Avatar
SCR has nothing to do with streetability. It's just a static figure, a build number. DCR is what is MUCH more important.
You said you want to run as much compression as possible, right? I'm running at closer to 13.0 and I have no problems (knock, etc.).
Old 08-01-2010, 10:47 PM
JB_97ws6TA's Avatar
Mahle pistons aren't very nitrous friendly, and I would stick with 5.7 rods if you plan on spraying.
Old 08-01-2010, 11:08 PM
RamAir95TA's Avatar
True - I missed the nitrous part.
Old 08-01-2010, 11:48 PM
slomarao's Avatar
If i am only hiting a 100 shot could I still use a 6 inch rod?
Old 08-02-2010, 08:37 AM
quik95lt1's Avatar
2 bolt main
Stock crank
ARP head bolts
LE 226/234 stick
Boltons
I ran TRW's aka Speed Pro pistons in my 355 for two years revving it 7000 on stock rods and crank. The Speed Pros are cheap and reliable I'd reccomend them.
Quick Reply: pistons/compression
