Bare heads - Trickflow
Thinking about getting these bare since I plan on using the springs I already have on my stock heads.
Who has done this? Would a valve job be required? If so I'll probably get the assembled version then keep the springs for spares or let someone have them cheap.
Might save money that way rather than getting them bare then having to buy valves and get the machine work done.
Opinions?
Opinions?
It's sometimes cheaper to buy them assembled, but you need to make sure they will be sufficient enough for your setup. Some setups require different springs with different install heights, etc. But since you are using your springs, then go for it. Are they for a future build or will they be complimenting your current engine?
Your heads stock with springs? Id get new valves and yeah id say u would probably need a valve job to insure valve seat angles are right. Or give AI a call and get the same package i got.
