madz28 tune
i didnt think they would be spinning the tires through the gears i was expecting faster shifts. i dont have the best tires in the world so it might be a contributing factor. when i go into a turn and it shifts the tires start spinning. i think thats what really bothers me the most.
ill run it for a little while and see how i like it in a few months if i dont like it ill have him reprogram it.
Your wording (perhaps not intentional) makes it sound like it is his fault (which sounds to me like he did what you asked). What I would have had him do is change the performance shift tables and left the normal tables alone. That way you can put in a switch and change to the hard shifting stuff when you want it and switch back to normal when you don't. This only works on 94-95 PCMs. Firebirds came with the performance shift switch, but Camaros didn't. The PCMs were the same, so the switch can be added to the Camaro.
I agree^^^ you kinda got what you asked for.. next time just say I don't want the nuts on the car to be "too big."
And Sumitomo tires aren't known for "grip" they are know for a good price.. Just take it easier around turns...
i went around a conner in the rain last night after making this post and the car shifted and the rear broke loose and i wasnt even accelerating i get it the tires arent great but to me it seems like very hard shift points.
wasn't really an option of like well i want x amount of psi there wasnt much description. this is what there is a list of options and and on says shift points and then it says not recommended to be used in conjunction with a shift kit.
im not a tunner so i have no idea. maybe there is only two setting for tranny psi. i think the shifts can be pretty hard and yes like i stated there crappy tires.
maybe the problem isnt in his tune maybe its some where else and that's why i asked the question. i would definitely use him again or recommend him. i just would recommend increasing the shift firmness to freinds.
