wtf i need help
Old 08-15-2010, 08:05 AM
GodsLT1's Avatar
Default wtf i need help
ok i have a 1993 camaro. i have had this car for about 2 years i drive it like a normal human lol. but i just did its 8 tune up since ive had the car { ngk plugs, msd wires, fuel filter, pcv valve, oil amsoil 0-w30, an oil filter}. an its been 2 days an my car is retarded. ill drive it around a it randomly cuts off an then starts back up right after.
like ill be driving at about 45 an the cuts off, then starts back up with out me doing anything. this takes like a matter of 3 seconds
i have no idea what to do. it doesnt have a miss fire. i have a dynaspark with like 750 miles on it. like i said i do plugs a wires on it every 3 munths so. i need some advise. could it be a grounding issue...... help plz
Old 08-15-2010, 08:26 AM
GodsLT1's Avatar
45mph at like 2 grand an the car seems fine then randomly shuts off an turns its self back on in like 3 seconds. an it only does it once every time i drive it...
Old 08-15-2010, 08:41 AM
Speedy's Avatar
This is usually caused by weak spark or a rich mixture. Check from the plugs (burnt plugs will mean not enough fuel, carbonized plugs will mean weak spark) and move back until you find the problem. If you have a new distributor that is likely not the problem. Check the strength of the coil (this can trick you), if it is okay try the ICM.
Old 08-15-2010, 08:47 AM
GodsLT1's Avatar
yea i did the plugs right after this started an it didnt help, the ones i took out were fine but i said **** it an put new ones in lol. i have the msd blaster coil could that have gone bad? an icm????
Old 08-15-2010, 09:14 AM
Badazz 97 TA's Avatar
Could be anyhting electrical, maybe fuel related. The coil could be acting up like you said. check out shoeboxs website and test it out. MSD sometimes has crap products. Your better off going with a stock 96-97 coil since it was the better one. The icm could be getting hot.
check out this website and start troubleshooting.
http://www.shbox.com/1/4th_gen_tech1.html
http://www.shbox.com/1/coil_testing.jpg
http://www.shbox.com/1/4th_gen_tech2.html#ICM_cooling
plugs and wires every 3 months? isnt that a little excessive?
Old 08-15-2010, 09:26 AM
vanilla89's Avatar
Check the opti harness for broke or damaged wires.
Old 08-15-2010, 09:40 AM
GodsLT1's Avatar
otpi harness is good that was the first thing i checked. what is the icm sorry i feel dumb for asking. an should i check the fuel rail an **** like that to see if there is something wrong?
Old 08-15-2010, 10:40 AM
Speedy's Avatar
Check that damn MSD coil first. I had one go bad on me with the same symptoms and it was really hard to tell that it was the problem. The ICM (ignition control module) is that little plastic thing above the coil:
The ICM can heat up and shut down temporarily also. Do the coil first.
Old 08-15-2010, 12:43 PM
aaronlt1's Avatar
i changed my opti and it went away my 4th one now i drive a 1993 ta i finaly got an opti that is vent for the 1993's awsome
Old 08-15-2010, 07:05 PM
GodsLT1's Avatar
ok so i asked a pro. lol my dad, an he figured it out it was the coil. so now she is running fine. thanks everyone for your help i would of never look at the coil. so thanks.
Old 08-15-2010, 08:44 PM
Speedy's Avatar
MSD strikes again. WTF happened to that company anyway?
Old 08-16-2010, 08:07 AM
GodsLT1's Avatar
idk i had there optispark an it was a complete waist. i was so mad that it failed as fast as it did. went to dynaspark never had a problem. the only thing MSD is good for is there OVC wires thats it. but o well what can you do
Quick Reply: wtf i need help
