Opti spark
Old 08-15-2010, 04:33 PM
1994 interceptor's Avatar
Default Opti spark
How can u i tell if my opti spark is goin out on my 94 z28
Old 08-15-2010, 05:15 PM
scj
scj's Avatar
has it ever been replaced?
Old 08-15-2010, 05:46 PM
No it hasn't I am having trouble figuring out what is wrong with my camaro after awhile of driving it will bog down for a second then regain all power right away I replaced the coil,did an injectio clean,changed out my fuel filter,did a tune up,checked my moduel it was fine,did a fuel pressure check and it was good it has no vaccume leaks that I know about somebody told me to change out the rotor in the opti cause it might be lose any suggestions????
Old 08-15-2010, 05:53 PM
ebeard's Avatar
Sorta sounds like what mine is doing... Is the idle normal? any SES light/ trouble codes?
Old 08-15-2010, 06:05 PM
lethal bird's Avatar
sounds about like mine also. It did that for about 2 weeks. Now its to the point where its hard to start, has alot of black smoke when reving, wont stay cranked, backfires when trying to keep it from dying, and just dies.
Old 08-15-2010, 06:22 PM
96capricemgr's Avatar
The cap and rotor are like any other distributor WEAR ITEMS but the ignorant folks of the LT1 community prefer to ignore it till it wears out them blame "bad design" and pretend the whole thing died instead of just a worn out cap and rotor.
Old 08-15-2010, 06:30 PM
BlownEarDrums's Avatar
^x980723578570375093478023485209374023720357203473 507504545747
Old 08-15-2010, 07:52 PM
The ses light does come on but no codes come up it says no saved codes
Old 08-15-2010, 07:56 PM
The Idle is fine for a while but it fells like it want to die out after a while
Old 08-15-2010, 11:39 PM
idformula's Avatar
Mines doing something similar, I just replaced the plugs and wires, the fuel filter, the pump tool a dump, checked with a gauge, and it still has a miss, pulled one of the plug wires and tested the spark, it was yellow. I took off the coil, and tested it, it was about twice the resitance, replaced it and no change, so tomorrow I'm taking it to a mechanic to dignose it, I'm stumped and need the car yesterday, I really don't know what else it could be.
Old 08-16-2010, 01:49 PM
Did the mechanic find out what the problem is
Old 08-16-2010, 09:43 PM
Does anyone have anymore suggestions on what to try next
Old 08-16-2010, 09:54 PM
Does anyone think I should try the opti wireharness
Old 08-16-2010, 10:01 PM
1994lt1ta's Avatar
lol id love to give some sort of good news, but im on optispark #4 and everything i have read in here are things i hoped and prayed for, but i hate to say it, but most likely just the opti, how many miles on the car?
Old 08-16-2010, 10:02 PM
1994lt1ta's Avatar
oh and a couple more questions...the longer it idles the shittier it runs? and when you punch it and get it near redline does it backfire and fall on its face?
Old 08-17-2010, 08:45 AM
It just turned over to 140,000 and it does back fire when I punch it all the way down what does that meen
Old 08-19-2010, 09:09 PM
1994lt1ta's Avatar
yea dude i read more of the things you said earlier in the post, and from what you told me, its def an optispark
Old 08-20-2010, 08:53 PM
Hey thanks man Thats kind of what I thought it was from every one telling me the same thing
Old 08-20-2010, 09:57 PM
shbox's Avatar
If the check engine light comes on, there pretty much has to be a code registered. Are you retrieving codes soon after the light comes on? Some codes will go away after a predetermined number of key cycles that the trouble is not detected.
Any time the opti is suspected, the harness should be checked, too.
Old 08-20-2010, 10:20 PM
Speedy's Avatar
Your cap an rotor are shot. They should be replaced every 30,000 miles. At 140,000 miles replace the whole optispark.
Quick Reply: Opti spark
