A/C Delete, what size belt?
Old 08-15-2010, 11:50 PM
ReggieWarrenJr's Avatar
Default A/C Delete, what size belt?
probably going to be deleting my AC here pretty soon, but didnt know what size belt im gonna need?
Old 08-15-2010, 11:54 PM
RamAir95TA's Avatar
From what I've seen it depends on which pulley you use (1LE, aftermarket, etc.). In my opinion, the best thing to do is to install the pulley, then measure the belt routing with a piece of string (or cloth tape measure), then buy 3 or 4 6-rib belts that are similar in length and see which one fits best, then return the others that don't fit.
Old 08-16-2010, 12:11 AM
robsquikz28's Avatar
exactly what he said, Its the easiest method
Old 08-16-2010, 12:38 AM
monster81's Avatar
if its the 1LE bracket, then u may retain the stock belt
Old 08-16-2010, 09:28 AM
great421's Avatar
Originally Posted by monster81
If its the 1LE bracket, then u may retain the stock belt
Yep - and Autozone sells them cheap!
Old 08-16-2010, 09:59 AM
DisturbedTA's Avatar
mine retains stock belt
Old 08-16-2010, 10:17 AM
Xposure's Avatar
When u go to autozone wat do u ask them for cuz i know the ppl working in these autozones are not all there at times?
Old 08-16-2010, 11:11 AM
Low N Slow's Avatar
I used the GM 1LE pulley and had to get a shorter belt. GM used 2 different sized pulleys on the A/C compressor, if you have the smaller pulley on your compressor you can use the stock belt. If you have the larger pulley like mine you need a belt that's 63.5".
Old 01-02-2015, 12:17 PM
wayneSS's Avatar
Good info!
wayneSS's Avatar
Love this site!
Old 01-06-2015, 08:56 PM
CamaroRacing12's Avatar
geeze i did it so long ago i cant even remember what size belt i used doh! i can't believe im now an old guy lol
Quick Reply: A/C Delete, what size belt?
