broken low oil sensor SOMEONE HELP
well as it reads my low oil sensor was leaking so i went to pull it off and when i slid it out i broke the plastic float off and it fell inside the oil pan i talked to a mechanic and he said it wouldnt hurt to just leave it in now my question is is how do i get the new one in around the cat
I could be wrong but leaving a hard piece of plactic in the oil pan doesnt seem to be to smart, You didnt ask but i got a GM one from GMparts direct and it was pretty cheap
Oil level sensor - 5.7 liter, 1993-97 - 5.7 liter, 1993-97
93-97 $13.60
http://www.gmpartsdirect.com/catalog/frameset.cfm
93-97 $13.60
I think mine is sitting in the bottom of the oil pan too because when I replaced it, that piece was nowhere to be found. I was told by multiple mechanics that its not going to hurt anything.
Sounds like it's time for some aftermarket Cats or LTs. I just changed my low oil sensor a few weeks ago, and I came thisclose to losing the little piece in the pan. However, to get the sensor in I did have to remove the Cat on my 96, which I was replacing anyway that day.
Good luck.
Good luck.
If it happened to me I would just be so annoyed that I would drop the pan and get it.
