hooking up new tach
Old 08-19-2010, 11:15 AM
ryanosborne's Avatar
Default hooking up new tach
if i ordered i new aftermarket tach what else would i need to order with it to hook it up? my stock one is broken.
Old 08-19-2010, 03:32 PM
or do you just clamp it onto a ignition whire
Old 08-19-2010, 04:07 PM
96silverram's Avatar
You need to trace the PCM wire for the tach. If you look on shoebox's site it should listed with the color code of the tach wire. You can do a search on here and find it pretty easy.
Old 08-19-2010, 04:49 PM
n2ocamaro's Avatar
Red ("A") connector on the PCM, white wire, slot 13.
Old 08-19-2010, 06:17 PM
thanks alot
