obd1 knock sensor ohms need help
im very stupid electrically and need to know if this is bad. I have the 5v referenace to the sensor but on my meter im reading 1.0-1.1 m ohms. my meter displays k ohms and m ohms only. So with it reading M ohms is this a good sensor or not. The desired specs are between 3300-4500 ohms (OBD-I)
Help please
Help please
Are you reading the sensor only, without the wire connected to it? Put the meter on kohms. That would be 3.3-4.5 kohms from the reference above. Make sure your lead connections are solid and good.
spec from your source is anywhere between 3.3-4.5k ohms. 3.8k is right in the middle but anything in the range should be acceptable. btw where did you get the spec from (not saying its wrong, just courious)
