Engine coming together but small problem...
Old 08-29-2010, 11:04 PM
BLWNLT1_T/A's Avatar
Default Engine coming together but small problem...
I ran into a small problem... The damn sprocket bolt washers are in the way and I can't get the optispark in... Any one sell an aftermarket bolt set, or should I just take off the washers?
Now my problem.... !!!
Old 08-29-2010, 11:09 PM
RamAir95TA's Avatar
Don't use those bolts. Use an ARP cam bolt designed for that purpose. Cam bolts have a smaller hex head that clears the optispark cloverleaf. That looks like run of the mill grade 8 hardware.
Something like this:
Old 08-30-2010, 12:03 AM
fex77k's Avatar
I ran into the same problem and came up with the same solution.
Old 08-30-2010, 10:24 PM
JAKEJR's Avatar
Or GM's dedicated bolts; they're different to allow the needed clearance.
Jake
Old 08-30-2010, 11:19 PM
WS Sick's Avatar
Those bolts look like that they would actually clear without the washers.
Old 09-01-2010, 12:04 PM
Been busy but I ordered these this morning...
http://www.summitracing.com/parts/ARP-300-1001/
Now I have to find a windage tray. Mine does not look to good. More to come soon.
Old 09-08-2010, 02:45 PM
Well **** put the bolts on and opti does not sit flush. It stops about an 1/8 of an inch before sitting flush with block. It will sit flush if I put some muscle on it but I feel this should not forced on in any way... Well it hurt if I take a little of the top of the ARP bolts?
Old 09-08-2010, 05:25 PM
leadfoot4's Avatar
Are you sure that the dowell pin on the cam isn't sitcking out too far?
Old 09-09-2010, 10:16 AM
How long is the Dowel pin supposed to measure on a 96 model?
Old 09-09-2010, 10:20 AM
RamAir95TA's Avatar
The dowel pin is supposed to protrude about .620" from the cam face.
Old 09-09-2010, 12:20 PM
wtf is .620 on a tape measure... lol
Old 09-09-2010, 01:17 PM
arctic white 94's Avatar
5/8 is .625
Old 09-09-2010, 03:34 PM
Well it turned out to be the cam bolts... What I did is stick something in the cavity where the dowel pin goes and measured how long it was and then compared it to the dowel pin. I had about 1/8" before dowel would bottom out... So I took off the bolts one by one and ground them down some more... After that the base of the opti sits nice and flush. I appreciate your help guys. Been so long I forgot how this thing goes back together....
Quick Reply: Engine coming together but small problem...
