Break in oil/trans fluid question
Old 09-01-2010, 12:13 AM
hitmanws6's Avatar
Default Break in oil/trans fluid question
My motor goes soon along with the trans soon and I need to know that you guys recommend for fluids. I know for the oil I need high zinc content, and for the trans I need non synthetic. Any input on what to use is appreciated
Old 09-01-2010, 12:17 AM
mrchyzy16's Avatar
Me personally dont buy into that gimmick of having to use different oils for break-in. I am using mobil5000 to break in my new motor and im not breaking a sweat over it. Use whatever you want, but thats my .02cents
Old 09-01-2010, 12:27 AM
hitmanws6's Avatar
I'm not going to go against common knowledge, you don't break in with synthetic
Old 09-01-2010, 12:32 AM
mrchyzy16's Avatar
I know you dont break in with synthetic oil. Mobil5000 isnt synthetic.
Old 09-01-2010, 12:39 AM
brucer's Avatar
i've never used anything but rotella oil on break in.. they say on roller engines it doesnt matter as much, but i will stick with what i know.. i know some hardcore dragracers that are using brad penn oil and they like it...
ive only ran a couple new rebuilt trans, a th400 and th350... Coastal trans fluid all the way..
Old 09-01-2010, 01:43 AM
hitmanws6's Avatar
ive heard good things about Rotella, also about Chevron Delo. What Dexcron? III? VI?
Old 09-02-2010, 12:02 AM
hitmanws6's Avatar
anybody else?
Old 09-02-2010, 12:06 AM
gregrob's Avatar
Chevron DELO 400 for the engine, and cheapo trans fluid for the tranny.
After breakin, switch to the oil of your choice.
Old 09-02-2010, 12:10 AM
hitmanws6's Avatar
what weight? and i figured as much for the trans, coastal seems like a decent brand. but which one? III? VI?
Old 09-02-2010, 12:14 AM
gregrob's Avatar
Dex III / Mercon
Old 09-02-2010, 01:44 AM
hitmanws6's Avatar
great, thanks for the help
Old 09-02-2010, 06:39 AM
FASHOOTER's Avatar
I would start out with a non syn 10-30 I like Lucas oil, Change it after 100 miles. Then run it for 500 miles and change again.
Trans I just use NAPA Dex III change after 1000 miles.
Thats what I did with my new set up Motor has 1400 miles on it and I run Lucas 10-40 in it now
Quick Reply: Break in oil/trans fluid question
