My custom Ram Air
My custom Ram Air
Okay when I went up to Ohio to pick up my car from my brother's place we went up to the Summit store in Cleavland. In the Bargin bin was the 98-02 F-Body Ram-Air kit for the V6 that they were selling for $50. Well considering the filter and the Radiator shroud is the exact same sold by K&N Ram Air kit for the LS1 I figured it was a steal. The V6 tunnel would not work so I went to Home Depot and picked up two 3' rubber couplers and a can of silicone. for a total of $65 I think overall it turned out pretty well.
[IMG][/IMG]
Side veiw
[IMG][/IMG]
Another one
[IMG][/IMG]
[IMG][/IMG]
Side veiw
[IMG][/IMG]
Another one
[IMG][/IMG]
Hey that looks familiar...
You got a GREAT deal they are usually outrageous
Something you may want to do....I took a dremel and cut a square int the rad support under the filter....That way when your going down the track the air dam will shoot air to the bottom of the filter instead of it just heat soaking on the metal....
You really can't see the hole in the pics because I cut it smaller than the filter itself so it wouldn't look bad....but if you look at the first pic you can kinda see it...
Matt
Matt
glad I could help!! I really think you will see an improvement at the track with it being cut on the bottom...after I made the cut I used some of the black stick on door trim stuff on it so you wouldn't see raw edges....
Nothing like a little TLC for the car after a long time away...
Thanks for the compliment! Mine is still a work in progress too...
Matt
Also I see you are military... Thank You for your service!! Glad you got home safe!! My dad left last week for Ballad. He is a Lt. Colonel this is his third deployment...
Matt
