Hooker slip-fit primary leaking issues?
I have been trying to trace this exhaust leak I've had for a while on the driver side. At first the culprit was the header gasket (or so I thought - it was good that I replaced it though because it was starting to crack). I put in a new gasket and I can still smell (eyes burn, too) exhaust from the driver side engine bay/header area. I can also hear an audible exhaust leak (that infamous tick). It does not leak from the header flange or from the collector - to - x pipe flanges. Has anyone had issues with the Hooker/Jethot slip-fit primary tube leaking? It sits pretty loose in there when I remove the first two header bolts (the primary slips right out, no effort). Any ideas?
