Cam Motion cams
Old 09-10-2010, 05:32 PM
Rockstar
Johnny-LT1-runner's Avatar
Default Cam Motion cams
Anyone here with an LT1 running one of their cams? Or at least know about them?
Old 09-10-2010, 07:52 PM
Corey @ Clayton Racing's Avatar
Cam Motion makes all my custom stuff, best around IMO.
Old 10-06-2010, 01:42 AM
01ssreda4's Avatar
From earlier today......
Old 10-06-2010, 02:07 AM
speed_demon24's Avatar
I would have no problems running one of their cams.
Old 10-06-2010, 02:12 AM
01ssreda4's Avatar
Me either
Old 10-06-2010, 02:31 AM
96lt1m6's Avatar
Cam Motion inside
http://www.youtube.com/watch?v=0_lS1...eature=related
Old 10-06-2010, 07:35 AM
ks my ss's Avatar
I have a cam motion speced by futural in mine.
Old 10-06-2010, 07:43 AM
Village Troll
SS RRR's Avatar
Cam Motion is one of the best around.
Old 10-06-2010, 09:07 AM
95 Formula's Avatar
I run cam motion specked out by futral motorsports in mine.
Old 10-06-2010, 09:26 AM
garage_queen's Avatar
I run a Cam Motion. My only recommendation would be to not let them spec out your cam. I was running a hotcam and decided to upgrade several years back. I didn't know how to spec a cam and thought it would be best to let them tell me whats best based upon my combo, flow sheet, etc. After replacing the cam and getting a new tune, I have not yet been able to run better NA times than what I did with the hotcam. I also dyno less than I did with the hotcam (360 vs 340 rwhp) on the same dyno. I have had a few others that do know cams take a look at the specs and all of them agree that it was done incorrectly. Once of the recurring statements is that a single pattern cam is probably the worst choice for an LT1. I dunno, just have not been happy with it.
I was looking for a step up and got what seems to be a step down
Duration:
Intake: 227
Exhaust: 227
Lift:
Intake: 556
Exhaust: 556
Lobe Center: 112
Centerline: 108
And my head flow numbers are below.
Old 10-06-2010, 12:44 PM
joelster's Avatar
Duration:
Intake: 227
Exhaust: 227
Lift:
Intake: 556
Exhaust: 556
Lobe Center: 112
Centerline: 108
I would question whether or not the install was done correctly before bashing the cam maker. That cam should mop up a hotcam. A single pattern camshaft is perfectly fine. Most cams are ground with more duration on the exhaust side because typically exhaust flow numbers are WAY behind intake flow numbers. In your case your exhaust flows over 80% of what your intake flows which is excellent. No need for additional exhaust duration if the valve and port work are getting the job done. I would have a second set of eyes go over the lash, check the install height on the springs, check the pushrod length, etc, etc...
Old 10-06-2010, 12:53 PM
LSWHO's Avatar
You also have to take into account the ENTIRE intake portion of the car and the ENTIRE exhaust. Just because the heads flow unevenly doesn't mean the rest does.
On that subject...
http://www.iskycams.com/techtips.html#2003
Old 10-06-2010, 01:02 PM
joelster's Avatar
On that subject...
I didn't say his heads flow unevenly. I think they flow excellent as far as intake to exhaust ratio. Probably why a single pattern camshaft was chosen.
Old 10-06-2010, 01:11 PM
LSWHO's Avatar
You didn't. I did. 80% is uneven. 100% is even. It's not bad like our stock heads are (though that's still 78%ish @.600), but it's still not "even." Our aftermarket exhaust typically makes it closer to even than heads alone will show. Most don't take that into account.
Old 10-06-2010, 01:18 PM
Not really trying to bash them, just stating my experience and opinion as the OP asked for. The cam is installed correctly, straight up, as recommended by Cam Motion using springs spec'd by Cam Motion as well. Push rods align perfectly. In contrast to my NA numbers, I have run better n2o times with their cam. I just don't run it NA anymore.
Old 10-06-2010, 01:31 PM
LSWHO's Avatar
One thing you could have done it split ratio rockers. That's what I may end up doing. 1.5/1.6 bring stock heads to about 93% I/E (@.600). Couple that with a single pattern.... or 1.6/1.7 if you have the room.
Old 10-06-2010, 03:57 PM
joelster's Avatar
It doesn't need to be even as in, intake flow= exhaust flow. That is why EVERY 4- cycle engine built has a larger intake valve/port than exhaust valve/port. There is a reason for this. An engine has gas (air) and fuel (liquid) going in one end, but just burned gas (hopefully) coming out. If the intake port can flow 250cfm, the exhaust port doesn't need to flow 250cfm. The combustion turns the air/fuel into heat energy and the overall volume of stuff going out is less than what went in.
Light a match
Place a 500cc glass over it
watch the match go out
What happened to the 500cc of air? Gone, poof!
Combustion is a chemical reaction that alters things.
I'm heading down the split ratio rocker track. I have plenty of room and a set of 1.7s on the shelf in the garage. Just need to measure the pushrod size for the 1.7s
I'd like to see the difference in using all the 1.7s vs split ratio with 1.6/1.7
Old 10-06-2010, 04:00 PM
idformula's Avatar
I'm supprised all the cheerleaders for AI and LE haven't come out yet bashing a company they have no experience with like in your last thread op.
joelster's Avatar
Did you dyno your car on the same dyno when you did the hotcam vs the Cam Motion cam?
Quick Reply: Cam Motion cams
