AI 226/234 results, very happy!
Well, its been a long time since i did my build but i finally got to put my car to the test this summer, figured I would post my results. I am VERY happy with my numbers, the drivability, gas mileage, power curve.... everything. its great for street driving and road racing which is what i want to do. All around good experience and would recommend this cam to anyone. Enjoy!
Car: 1995 Camaro Z28 6Spd - currently 97k miles (swap done at 92k miles)
Setup:
Tires: Street Tires - 275 Eagle F1s (not the nice ones)
Suspension: Stock minus control arms, SFCs.
Weight: Full as it gets. No weight reduction, sub and amp in the trunk. 37xx with me in the car and a half tank of fuel.
Clutch: Spec Stage 3
Track Results:
Track: US131 Motorsports Park - Martin, MI - NHRA Track
Best ET: 12.91
Best MPH: 111.52
Video of another pass that day:
http://www.youtube.com/watch?v=_H7Rt3CSxgk
Dyno Results: (Dynojet/Egojet)
Max HP: 373 rwhp
Max Tq: 352 rwtq
Video:
http://www.youtube.com/watch?v=B2o0YICsaz8
I think the track and dyno results could have been better with a higher rev limiter. The only reason I haven't raised it yet is because my laptop's hard drive crashed and I just haven't gotten around to getting all the software running again.
Setup:
- Shortblock: Untouched Original Rotating Assembly
- Heads: Stock Casting milled .020"; Stock spec valve-job on intake side (guides were worn); Machinist did "some cleanup" for me as a favor but just look like he made some scratches here and there. Port volume is stock to my knowledge. Unfortunately they probably don't qualify as stock heads as a result, but they are close. 11.4:1 static compression with impala gasket.
- Intake Manifold: Original, untouched
- Throttle Body: Original Untouched
- Cam: AI 226/234 Cam Kit
- Intake: LS1 Lid conversion (this REALLY helped on the butt dyno)
- Water Pump: Electric Water Pump (CSR)
- Tune: Self-tuned by me
- Rev-limiter: Stock 5850 RPM. Left it alone for longevity. I had thought the stock setting was 6200 - wrong. will be changing this soon.
- Exhaust: Pacesetter LTs > 3" Duals w/h-pipe > Flowmaster delta 40s dumped at axle
Track Results:
Best ET: 12.91
Best MPH: 111.52
Max HP: 373 rwhp
Max Tq: 352 rwtq
Video:
I don't know what the lift specs are for that cam, but I run a 226/234 .568" lift on a 111 lsa ground by Erson from Joe Overton and you see in my sig what that cam, with the right combo, is capable of, even with more cubes...Based on the duration, that Ai cam should be great. I agree that you will pick up with more gear and more rpm..I only spin my 383 to 6300-6500...I won't fault you for playing it safe with a stock higher mileage shortblock though...
--Alan
--Alan
That's making some nice power for near stock heads, congrats! That 60' needs a bit of work though. Were you spinning bad off the line or just not used to running it at the track? Some dr's would make a huge difference. With that kind of power and that clutch you should be able to get below 2.0 in the 60. If you could get a 1.7-1.8 you would be in the very low 12's for sure. Consider 4:10's too, they are the perfect gear for the M6, makes launching easier too.
I actually had drag radials for a week and got rid of them. I would have for sure broken something with them by now, and im just not that concerned about traction to put parts at risk. I also attribute part of that to still having the stock torque arm (yea, i know...) But I already restrain my shifts because the car usually goes sideways into 2nd and 3rd if i hit those gears as hard as i can.
Nice numbers. I have the same cam and it works really well for me also. Get that 60' down and you should see alot better quarter mile times. I ran 11.90 at 111mph first time to the track last year. Its all in your 60.
like everyone else, the 60' needs to come down. Not trying to dog you being consistant with a manual trans car, but sometimes consistantly bad 60's arnt a good thing . Just saying the car has more in it, as im sure you know. the launch in regards to spinning tires was a nice launch, but it just shows how much more the car could have in it! especially with those dyno numbers!
very nice man! i hope i can get some parts together for a ls1 lid conversion, i need a new intake anyways, good to hear so much good stuff!
It is hard getting the launch right with an M6, that's for sure. I was much more worried about breaking before the 12 bolt. Since then I'm not as concerned launching it around 4k or so. Like I said 4:10's and dr's make it easier to 60 these cars. Good mods to consider if you want to see better times.
However.... my rear shocks were shot as can be, and those have been replaced since that track day. Its possible there is a bit more on the table now than before, but my clutch/tire combo makes it tough!
