stock oil cooler questions
Old 09-13-2010, 04:23 PM
ElkySS's Avatar
Default stock oil cooler questions
what is this thing for? its not like a conventional oil cooler considering oil doesnt flow through it? why is it there? i know it wont hurt anything if i took it off but why would someone want to keep it on?
Old 09-13-2010, 06:00 PM
TheTransporter69's Avatar
bump, i wanna know more about this too, i thought i heard about people deleting it and getting a little more oil pressure.
Old 09-13-2010, 06:17 PM
defaultexistence's Avatar
here's the idea...the cooler adaper above the oil filter acts as a heat-sink radiator fluid is supposedly cooler than engine oil or vise versa at the filter.... so it is supposed to help out with engine temps if i understand that corectly...i feel it's a bit lacking in its design and performance IMO. At this time i had deleted mine to make way for the headers ..I will however be adding a performance one back in @ some point, aswell as a trans cooler
Old 09-13-2010, 06:36 PM
wrd1972's Avatar
I have heard that it helps the oil reach operating temps quicker for better emmisions more so than actually cooling. Not sure if its true, just what I read on CF once.
Old 09-13-2010, 07:35 PM
RamAir95TA's Avatar
It's useless. So useless, GM decided to get rid of it beginning in 95.
Old 09-13-2010, 07:39 PM
Rob94hawk's Avatar
It's almost 2 pounds of useless metal, cooler and hoses. Especially if you use synthetic oil exclusively.
Old 09-13-2010, 07:48 PM
wrd1972's Avatar
I bought my 1995 on January 2nd 1995. I assume it was built late 1994 and mine had it. Also useful to know they did not install it on any LT1 vettes as far as I know.
Old 09-13-2010, 07:53 PM
oh yeah ive heard that the lt1 vette water pumps are a little different and didn't have that port. might be the way to go if a guy does plan on deleting it and are looking for a new water pump.
Old 09-13-2010, 10:29 PM
camar0corey's Avatar
It's another one of those things that once its gone its so convenient. Then you forget what it was like having one, go work on a stock or near stock car and start swearing at all the extra junk in the way!
Its like delete delete delete with these cars. EGR/AIR, oil cooler, sooner or later ABS. So much extra un-needed crap. Maybe I will one day get around to the LS1 lid setup also, gain even more space to work! Kinda miss my carb'd 83 Z28 sometimes, all the space in the world to work.
Quick Reply: stock oil cooler questions
