Shaft rockers
Old 09-13-2010, 08:42 PM
Money1's Avatar
Default Shaft rockers
Is there a company out there that makes shaft rockers
for the 21 deg Trickflow heads
Old 09-13-2010, 09:36 PM
Doughboy692's Avatar
Have you called T&D or Jessel?
Old 09-13-2010, 09:40 PM
1badzee's Avatar
Pretty sure the TFS 21* heads still use 23* valve train..
Old 09-13-2010, 10:02 PM
96lt1m6's Avatar
Yup,sure will....
Jesel ftw
Old 09-14-2010, 02:10 AM
Puck's Avatar
23* valvetrain still works on the TFS 21* heads. What RPM are you planning on spinning, and what is your cam and rest of the valvetrain?
You many not need shaft mounts, but if you already have to buy studs, guide plates, rockers, and pushrods then you might as well go with them for the extra cash if you can spare it.
FWIW I have DRE shaft mounts, which are the OEM for many of COMP Cams high end rocker models.
You will need aftermarket valve covers as well.
Quick Reply: Shaft rockers
