since searching hasn't helped... tuning
I am wanting to get a full tuning set up. So far I've seen that Jet now has a datalogger? Is it included in the price? Can you hook up a wideband directly to it's datalogging? Is there a certain one that will/won't work?
I keep seeing that there are issues with the datalogging but NOBODY gave specifics.
I DO NOT want to switch to ODB1 because I will fail emissions and I can't just swap back to a different pcm to pass, as that would defeat the purpose.
I have looked and looked because I have a 97 as well and there is the jet thing and then there is http://www.tunercat.com/
I would call them and see if it will do data logging as well on the obdII. I looked through real quick and did not see anything about it supporting data logging on a 97 odbII
I wish I could offer more, but all I know is that Tunercat doesn't datalog with OBDI, so I doubt it does for OBDII. It's just a tuning software. For OBDI, you need another logging system like datamaster or freescan to log data. Not sure about OBDII, but I'm sure there's something out there, probably more expensive than the OBDI stuff.
JET DST does not include a datalogger as far as I know. I am using a version that is a couple of years old but I have updated it throughout the process and no datalogger in sight. If you want a datalogger that will log WB then your best bet will be Wester's garage ecm pro scanner. It is a logger that works with the JET DST cable. There was also mxscan but they had compatibility issues with vista and 7 so they pretty much scrapped the whole deal. FWIW I use JET DST with the ecm pro scanner and it works fine.
