Help, my car wont run!
Well last week i was putting on my new bfgs, mounted and then lowered the car from the lift, cranked up, cranks like crazy, nothing. was running good to this point. checked fuel pressure and was at 40. pulled a plug wire and put a test plug on and had some spark, but not really strong. scanned it and all it had was a low resolution signal to dist. So i cleared it and let it sit thinking the opti is dead. 6 hrs ltr my dad fired it right up. so next day i get it, fire it up, 2 minutes of idling and it shuts off, same thing. recheck fuel and spark, same. no codes. did some research and seen that the ICM goes bad. so today i put a new coil and module on and fix a ground strap on there going to frame that was messed up, and still nothing... my security light is always on, but has been since i got the car. if it was VATS it wouldnt crank at all right? any ideas here? i need a car for work and my dad lent me his car, but i need it running to drive or trade in cause it will be my down payment on another ride.. any tips/info greatly appreciated...
Could also be the ICM and/or coil. Any electronic component that gets hot can fail. Have the ICM tested at a parts store to see if it's bad (preferrably while it is still hot). Both of these items are far less labor intensive than an optispark and are far less expensive as well.
yeah i think im gonna have to find time to tear it apart, but with work, packing, trying to close on a house and keep my near due date wife happy and calm and not pop the baby out 4 wks early, im kind of at wits end. i may sell as is, but would be easier if it was running.
If it is the opti, just follow the directions on shbox. I did my first one in late Nov, freezing my *** off, and it only took about half a day. I kept going back in to warm up. Wife should understand if you tell her.
well changed the coolant temp sensor, the one on the water pump that reads to the ecm. now it starts better, runs and doenst shut off at 190 like before. now, as i rev it up and down, easy, not slamming it up and down, it stalls after a few of those and wont restart. let it sit a few minutes and it fires up and idles. so i dont know if the opti is heating up and crapping, or a fuel pressure issue. ill have to run a pressure gauge on it and do it again, but im wondering if its a weak spark and it floods or what. think its gonna go for sale as is, with all new parts ive done and its a 6 speed, i dont have time to fiddle with it. its a 96 six speed car. good project.
