reverse issues
Location: Cold upstate Newyork roads unworthy for a lowerd camaro
reverse issues
for some reason i cant seem to get my car in reverse while its running after a hard high speed highway run any1 else ever have this problem i have a built tremec i havent tried for a few days idc really since all other gears work as if nothing is wrong aside from my 85mph vibrations that ive learned to ignore hearing it may be my input shaft im a mess lots to do this winter any info and help would be great
what do u mean by highway run? once ? or after every highway run?
There is a known problem with reverse from factory that appears after age.
Your 85 mph vibe may very well be the stock iron driveshaft...or an inbalance. in either case ive seen the LS1 alumi shafts cure the problem....altho it seems it kinda moves it up to 120ish....but everything under is much much better
You can get an Ls1 shaft at your local junkyard or maybe ebay.
You dont have to pull the tranny if the problem is just reverse...altho a little difficult u can run the fix by removing the tailshaft of the T56 giving u access to the reverse gear slider arm. But if this is not the only place with problems then yea u should pull it.
Nope not your finger....yea maybe her hair....but bad synchros....yea...time to pull it.
