taller oil filter?
Old 09-21-2010, 02:09 PM
ElkySS's Avatar
Default taller oil filter?
i heard there was a taller filter for f body lt1s. what car is it actually for?
Old 09-21-2010, 02:14 PM
wrd1972's Avatar
Usually trucks.
I used to run the tall K&N but when I went long tube headers it no longer would fit. Got em sitting on the shelf.
Old 09-21-2010, 02:25 PM
duh
duh's Avatar
look up the filter for a 98 K1500 chevy 4x4.....works like a charm for me...
Old 09-21-2010, 02:45 PM
hitmanws6's Avatar
I ve used it on older chevys, I believe it fits the old 427 block that was in the trucks
Old 09-21-2010, 03:34 PM
lttransam's Avatar
i dont know how much taller your talking about, but all the stock ones that go on are really short, so i use the napa 1214 in the blue box, its about the right size for a normal motor, not that short piece of crap lol
Old 09-21-2010, 05:49 PM
fex77k's Avatar
Mobile 1 pn 302 or K&N pn 3002
Old 09-21-2010, 05:57 PM
brucer's Avatar
are you talking about the old 2qt oil filters?
dont know if they'll work with headers.
i'm running a 2quart stp S373 on my 94 lt1 camaro with manifolds.
wix 2qt filter is 51794
ac-delco 2qt filter is pf932
purolator is L40084
Old 09-21-2010, 11:34 PM
ElkySS's Avatar
i think it will work if i delete the oil cooler. thanks
Old 09-21-2010, 11:47 PM
fex77k's Avatar
I run a taller oil filter with the oil cooler.
Old 09-22-2010, 01:37 AM
brucer's Avatar
heres the specs of the 2qt wix filter.
Old 09-22-2010, 07:15 AM
ThreeHonks's Avatar
do they make a big napa gold filter like that?
Old 09-22-2010, 11:27 AM
AChotrod's Avatar
I just use a K&N filter that has the nut on the bottom for easy removal. I hated trying to get off filters with LTs on the car.
Old 09-22-2010, 11:41 AM
LaVy's Avatar
I always just look up 97 K2500 6.5 diesel/454 gas wix filter its about an inch and a half longer.
K&N filters are easier to remove with headers because they have got the nut but wix cost half as much, and most murrays/o'rielly's stock them now.
Old 09-22-2010, 11:45 AM
brucer's Avatar
2qt napa gold filter
http://www.napaonline.com/Search/Det...794_0294400437
Old 09-22-2010, 12:30 PM
fex77k's Avatar
That's a tall 302 next to the wix, the thing is really tall there is no way I would run a oil cooler with that filter.
Old 09-22-2010, 12:33 PM
ElkySS's Avatar
do they have a mobile 1 that tall?
Old 09-22-2010, 12:44 PM
fex77k's Avatar
I don't know, The K&N is 2002 for stock 3002 for tall 6002 for nasty
Old 09-22-2010, 12:49 PM
speed_demon24's Avatar
I run the tall pure one. Since it's yellow it helps me locate it during oil changes to remove it.
There's absolutely no reason to run a tall 2 quart filter on an lt1
Old 09-22-2010, 07:49 PM
1994Z28Lt1's Avatar
i run the AC Delco Pf 1218 with the stock oil cooler and LT's, the bottom of the filter is still comfortably above the oil pan as well out of harms way.
I ran the tall Mobile 1 filter once and it sat about even with the bottom of my oil pan which is probably ok but didn't want to risk it
Old 09-22-2010, 08:52 PM
ThreeHonks's Avatar
thanks! exactly what I was looking for
Quick Reply: taller oil filter?
