Tuner Cat Problem
Tuner Cat Problem
Ok so I connect the USB cable to the car, the other end to a computer. Open TunerCat, and everything is grayed out. Disconnect, connect again, no difference. Reinstall Tunercat, no difference. Get updated version, no difference. Try on a different computer with XP instead of Vista, no difference.
What am I doing wrong guys? I got the ALDL cable and TunerCat 2.25, and I'm using it on a 94 LT1.
control pannel > system > hardware >device manager
look under com/lpt ports do you see the cable listed??
I did install the drivers and the system recognized it just fine. I was actually able to get datamaster to recognize my car (rpm gauges goin up and down n **** on the monitor...so narley lol) so that's not the issue.
It does seem like everything is locked out but I used my friend's code to register it and it says it's registered. So I dunno what I'm doing wrong?
Actually I didn't install any $EE file. I been looking for it but couldn't find it...my friend never got his tunercat to work (and hes too lazy to figure it out) and he didn't have the $EE either. Could be why neither of got it to work?
thats probably the reason its not working... the definition file isnt installed...
you might have to buy the $EE definition file from tunercats, its like $20....
you need to look in the main program folder of tunercats and check and make sure the pcm_ee.tdf file is there, think the file path would be c:/program files/cats/tuner..... there is also a pcm_ee.chm file its the compiled html help file, it has all the help tips..
Appreciate it bro.
By the way if anyone's on a budget and is trying to get the files...I can hook you up.
