hooker super comp lts
Old 09-23-2010, 06:55 PM
94maro's Avatar
Default hooker super comp lts
ok i just bought some hooker super comps for realy cheap never been installed...and one of the pipes comes apart from the header to go around the steering thing..i was wondering if any one has had a problem with it leaking? and if so wat did u do to fix it? thanks
Old 09-23-2010, 10:36 PM
tbag_skywalker's Avatar
I put some high-temp RTV on the outside of the smaller piper when I pushed them together.
Still leaks a tiny bit, but I honestly can't think of any other solutions. I guess I was hoping someone would have come up with a better one by now lol.
Old 09-23-2010, 10:50 PM
1badzee's Avatar
Mine leaked bad.. I gooped a bunch of high temp copper rtv on the smaller pipe and shoved it back in there. Hasn't leaked since.
Old 09-23-2010, 11:47 PM
idformula's Avatar
Copper ultra is the schiz nit!
Old 09-24-2010, 07:33 AM
quik95lt1's Avatar
i used the permatex copper hi temp silicone and have never had a leak on mine........it shouldn't leak at all as long as the pipes arent dented or warped.......like i said i've neva had mine leak......
Old 09-24-2010, 07:44 AM
SpeedDensityZ's Avatar
I use high temp RTV as well. Doesn't leak.
Old 09-24-2010, 10:05 AM
Well don't I feel like an ***! Everyone used the same solution as I did and I'm the only one who's still leaks lol
I even used the ultra copper RTV lol
Looks like I'll have to try it again...
Old 09-24-2010, 01:27 PM
94maro's Avatar
ok this is what i was planning on doing just wanted to make sure that some didnt haver a better idea..lol i was thinking of like a small clamp like some do on the exhaust bit it would hvae to be a very small one..
Old 09-24-2010, 01:39 PM
quik95lt1's Avatar
pull it apart and clean the pipes with a wire brush where they slide into each other then coat the male side with rtv and pop it in and make sure you give it overnight to dry and harden up before you fire it
this should take care of it unless the pipes are damaged
nope no need for the clamp all that will do is distort the pipe opening.....copper rtv will work justttttt ffinnneeee.....again like i said above just give it like 12 hours of drying time before you fire it up
Old 09-24-2010, 01:46 PM
94maro's Avatar
hmm thats a long time..lol might *** that part up..lol i like hearing it..guess ill have to fix the rest of my exhaust before firing it then..lol thanks
Old 09-24-2010, 01:52 PM
quik95lt1's Avatar
np bud glad i could hellp
Old 09-24-2010, 01:54 PM
1badzee's Avatar
Yes, DEFINITELY let it cure first. I let mine sit for a whole weekend. When I got back to it it was perfect!
Old 09-24-2010, 02:00 PM
94maro's Avatar
dam..lol car must not have been able to start yet ha?
Old 09-24-2010, 02:13 PM
1badzee's Avatar
Not sure I understand what you mean lol
Quick Reply: hooker super comp lts
