Car running weird, may have gotten the opti wet?
Alright i just went down the road to pay the gas bill and low and behold, rainstorm. Anyway i didn't notice anything until i pulled into a store to turn around having passed the gas place. I noticed when i went to pull out it was idling kinda low and had a slight hesitation but nothing major. Well i payed the bill and as i went to pull out it did the same but almost wanted to die, push in the clutch and it revs fine try and move and it was almost like it was running out of gas, which i first though actually.
Well i pulled out on the road gave it some gas and it finally kinda kicked and started driving normal. Drove it all the way home and the i could tell its kinda missing but not really trying to die. I popped the hood and the front of the motor isn't wet nor is the opti, but i know that doesn't mean much. I'm going to go check the fuel pressure in a minute just to be sure the pump isn't dying but i wanted to see what you guys think.
The opti is less than a year old and is a summit acdelco.
Alright well i went out and cranked it and it started fine and idled fine. Backed up just fine and pulled forward just fine. So i drove it about a half mile down the road and back and it took off just fine and drove pretty much fine but i could feel the slight hesitation/miss while driving. Pulled in to turn around and it was idling low, ~500rpms. It revved pretty good put would miss bad if i tried to hold a certain rpm.
So i went to drive it back and it was hesitating really bad, it has the symptoms of running put of gas (yes it has gas in it). So i got home pulled up and it was still idling low, but when you kill it and crank kit back up it idles and revs fine. Its like it messes up when you drive it any amount of distance besides backing up and pulling forward.
Any ideas?
Any ideas?
Yea i'm hoping so, like i said i'm gonna let it sit until tomorrow to let everything dry. If that doesn't work its time to investigate. Only good thing is i have a new fuel pump if that turns out to be the problem, which its probably not.
Alright so far what i've figured out is that when you crank it and let it run, it acts just fine. After it idles for a minute or so is when it starts running rough. When it starts running rough you can go to the back and see its running rich and is choppy. Almost sounds like a small cam, just for reference.
Just a thought but could the o2 sensors have gotten messed up causing it to run like crap after a bit?
And still no cels
And still no cels
Actually we figured the fuel pump was giving out because it was reading weird pressures so i jsut went ahead and changed it. It ran fine but still had a slight hesitation. Well this morning i dropped my girl off and was about half way home when it started to hesitate worse and sputter some, but if i put it in 5th instead of 6st and ran it at 2000rpms it ran pretty clean. So i drove it like that and after about 4 miles the check engine light started flashing and it started to cut up and "buck" pretty good. The light would flash then stay on, if i gave it gas it would flash and then stay on.
I'm almost certain its the o2's, i was actually getting on here to get an opinion. A couple of my friends have scanners so i can hopefully get it scanned before hand, but i have a set of 02's i can swap in if thats the problem. I'm just lucky my buddy lives in the town i had to go through to get home so i just stopped there.
If the O2's fail then the PCM reverts back to basic open loop (factory programmed) parameters and you should get a SES code. If these open loop parameters are factory original in the tune, it will not run the way you are describing. The only noticable negative impacts would be maybe more emmisions and a hit to the MPG's. IMO, this is not a O2 problem. Still sounds like ignition to me assuming your fuel pressures are in spec.
Did you mist the wires like Speed suggested above?
I checked the codes and it was just random misfire detected. Cleared it and drove it around the block and it was cutting up real bad when just cruising but ran alright. So i'm pretty sure i fouled the o2's out. I'm going to try and change them later. Its running similar to what it did when i first got it and it was the o2's
So it was the o2's. They were blaaaaaaaaaack. lol anyway put some old ones i had in and it runs fine. its saying that one isn't giving a signal so i have to check that out tomorrow
My 02's were shot too.........but it turned out to be because of a bad FPR. Swapped the plugs (only bled once!! first time doing plugs on an LT1) and both o2 sensors yesterday. Going to install the FPR tomorrow.
