what rpm should i shift at?
Old 09-24-2010, 02:55 PM
ElkySS's Avatar
Default what rpm should i shift at?
396 afr 195 street heads
cam is a 236/242 .575/.575 112
iv been shifting at 6300 but i was just guessing.
Old 09-24-2010, 03:19 PM
ss.slp.ls1's Avatar
Spin it til it blows, then back off a little...lol, jk.
Find out were you peak power is, that will determine what your shift rpm should be. Most cars will carry a little after peak power, so you need to see where your power starts dropping off.
Old 09-24-2010, 03:23 PM
wrd1972's Avatar
Time to hit the dyno.
Old 09-24-2010, 04:05 PM
RamAir95TA's Avatar
Originally Posted by wrd1972
time to hit the dyno.
+1...
Old 09-24-2010, 04:17 PM
speed_demon24's Avatar
I punched some #'s and came up with ~6500.
Old 09-24-2010, 04:39 PM
TABBED 5.3's Avatar
if you cant get to a dyno you can get a better guesstimate at the track. try adjusting shift points and see where it picks up or loses mph. a shift light will help a lot better than trying to watch the tach especially if its the factory tach.
Old 09-24-2010, 05:05 PM
ElkySS's Avatar
i would hit the dyno i just havent had the cash or time yet. i dont have a shift light but iv been considering it. guess ill have ti try that
Old 09-24-2010, 05:50 PM
Wicked94Z's Avatar
head to the track, shift for best mph.
Old 09-24-2010, 06:09 PM
Village Troll
SS RRR's Avatar
It'd drive me crazy not to know where power peak is. I'd get it dynoed. It is crucial to know where to shift and what tire/gear combo would work out best.
Old 09-25-2010, 04:39 PM
AChotrod's Avatar
Originally Posted by ss rrr
it'd drive me crazy not to know where power peak is. I'd get it dynoed. It is crucial to know where to shift and what tire/gear combo would work out best.
x2!!!
Old 09-25-2010, 09:46 PM
SpeedDensityZ's Avatar
I say between 6500-6800. I shifted my 383 at 6800 with similar cam specs.
Old 09-26-2010, 10:42 AM
TWS
TWS's Avatar
Dyno graph! As a general rule of thumb, you want to set it up to shift at peak power, dropping to peak torque. That will get you roughly in a good ballpark. When programming my shift points we were aiming to only have a 900-1000 RPM drop on upshifts, going down the track at WOT. Coverter selection is huge here. Think I made peak at 6700, and had it shifting at 6850-ish.
Old 09-26-2010, 10:57 AM
96capricemgr's Avatar
Valvetrain plays into this, have a crappy valvetrain that floats just past peak like a lot do and you are going to want to shift just shy of that. Have a good valvetrain where power slowly declines after peak and you might find it best to shift 500rpms past to keep you at the top of the power curve the longest.
In Datamaster you can look at the mph graphed and you can see if acceleration flattens out from shifting too high or if you drop to too low an rpm after shift and it flattens out from that.
Old 09-26-2010, 11:29 AM
ElkySS's Avatar
well i dont think ill have any issues with valve springs. iv revved to 7k during burnouts . i guess ill play with my shift points when i go to the track next.
Old 09-26-2010, 12:13 PM
You won't notice it during burnouts when there's no load on the car. In upper gears it will feel like you hit the limiter though.
Example:
http://s86.photobucket.com/albums/k1...=VIDEO0011.mp4
Quick Reply: what rpm should i shift at?
