walbro 255 lph pump
Old 09-28-2010, 10:14 AM
duckvader's Avatar
Default walbro 255 lph pump
what is needed to install walbro 255 pump. do you have to completely rewire or use stock wiring. the reason i ask is some show a wiring kit. also on summitt website which pump or kit would you buy for 1997 firebird lt1.
Old 09-28-2010, 12:09 PM
bowtienut's Avatar
You don't have to rewire, but running a thicker gauge hot wire will reduce voltage drop to the pump and therefore increase capacity, both with the Walbro and stock pumps.
If you're just replacing the stock pump and not planning on over 400 rwhp, then the stock wiring is sufficient.
Old 09-28-2010, 12:13 PM
qc97z's Avatar
When I pulled the fuel pump from my 97 in order to drop in dual 255's, I pulled out a single 255. Someone had already replaced the pump. It was using stock wiring, and ran just fine. The car probably had 320 RWHP though at the time.
Old 09-28-2010, 05:31 PM
duckvader's Avatar
1 should be around 400rwhp, i hope. so where would you run hot wire from.
Old 09-28-2010, 05:54 PM
Wicked94Z's Avatar
I'd run it from the post on the alternator. I made 480 rwhp with no hotwire kit on a single 255, I wouldn't worry about it much at your power level.
Quick Reply: walbro 255 lph pump
