For anyone doing the Heated 02 Conversion with BOSCH 02's
After a ton of screwing around I found out the wiring for the heated 02 conversion using Bosch 02's is different than many of the write ups around say it is.
I'm using Bosch 4 wires - Grey, Black, and 2 White wires. Here is the original walk through, and here is the way they should be wired! (for Bosch only)
D -- White -- Power for the conversion setup.
C -- White -- Ground for the conversion setup
B -- Black -- O2 Feedback for the conversion setup
A -- Grey -- NOT USED on the conversion
http://www.fastbird93.com/Installati...Conversion.htm
Thanks to Sean, the maker of that site ^ for the walk through and help getting me squared away. Can we get this stickied so there is no confusion in the future?
