cravy viberaton at 95mph
Old 10-05-2010, 10:23 PM
gregp68's Avatar
Default cravy viberaton at 95mph
ok its a 97 m6 camaro i have checked everything. i have a new clutch an ls1 driveshaft and new tires. the viberation comes up through the console. it starts at 95 mph and gets worse the faster i go. any sugestions
Old 10-05-2010, 11:43 PM
MasterTomos's Avatar
What do you have for exhaust? Have you recently changed the transmission mount or motor mounts to polyeurethane ones? Did this happen before, after, or always when you put the new driveshaft in? Did you have the driveshaft balanced? What condition are your tires in? Has your car ever had allignment work or been in an accident you know of?
Just several possibilities and things to think of.
Old 10-06-2010, 07:19 AM
ale76051's Avatar
Mine does that, it used to start at 105 but since I changed gears it's now at 75. So I'm thinkin it something in the tail shaft because my whole driveshaft was twisted before I got that replaced
Old 10-06-2010, 09:35 AM
wrd1972's Avatar
Post 22, 28
https://ls1tech.com/forums/lt1-lt4-m...tf-vibe-2.html
Mine happens around 83MPH and I have 4.11 gears.
If you have 3.42 gears, that accounts for the higher MPH than mine.
Sounds like we have the same problem.
Old 10-06-2010, 12:44 PM
Sounds like you all have "Viberaton" issues
Vibration is the word yur looking for OP
Old 10-06-2010, 01:27 PM
qc97z's Avatar
^^ Useless jackass post. Doesn't help the OP at all.
Old 10-06-2010, 01:34 PM
ElkySS's Avatar
nonsense. he may have an essay due soon. he might have made him go up a whole letter grade.
Old 10-06-2010, 01:39 PM
LSWHO's Avatar
You guys are cravy!
Don't they blame the viberation on the LS1 driveshaft??
Old 10-06-2010, 01:47 PM
And this post was so much better, at least I've contributed to this thread. Just poking a little fun, no need to name call.
Originally Posted by LSWHO
You guys are cravy!
I've not heard of the ls1 driveshafts having this problem. Not sure if it's common or not?
Old 10-06-2010, 02:29 PM
gregp68's Avatar
tires are brand new. drive shaft was checked it was good. when i did tires i had the alingment done. the mounts are stock. the car hasnt been in a accedent. i was thinking it was in the tail shaft of the trans but im not sure
Old 10-06-2010, 04:19 PM
alexcoreas's Avatar
About 4 mounths ago a Guy had the exact same problem, he checked his clutch, rear end, drive shaft . It ended up being his tranny it might be that also. I'm having the same vibrations and I'm gonna have them inspect my tranny
Old 10-06-2010, 05:15 PM
gregp68's Avatar
well i called jason at tdp and talked to him for a little bit. he seems to think the samething. im going to take it up there and have the trans rebuilt. it suxs but i have 99000 miles on the car so i guess its time
Old 10-06-2010, 05:19 PM
wrd1972's Avatar
OP.
Did you even see post 4?
Old 10-07-2010, 10:42 PM
gregp68's Avatar
yea i saw it. thats why i called him he seems to think its not a main shaft. we both think its a tail shaft bearing. its not a common problem but he dosnt believe it can be much else
Old 10-07-2010, 11:30 PM
alexcoreas's Avatar
Hope that's all. And ur vibration goes away. ima have mine inspected
Old 10-08-2010, 07:22 AM
wrd1972's Avatar
I replaced the tailshaft bushing in mine twice and nothing changed. But if you want to change it, its rather easy to do. Just pull the rear housing off and take it to a tranny shop and have them press the old bushing out and install the new bushing. Then reinstall the housing.
Old 10-08-2010, 07:24 AM
Bowtie Boy's Avatar
You guys are cravy!
LS1 DS is balanced and is a cure for the common LT1 DS vibration issues. So there is little to no chance his LS1 DS is causing the problem, unless its an LT1 DS and he got had.
Old 10-08-2010, 08:54 PM
gregp68's Avatar
there is huge differance in the look of the ls1 ds and the lt1 ds. i know i for sure i have a ls1 ds.
Old 11-30-2010, 09:58 AM
96lt4c4's Avatar
Did you ever figure this out?
Old 11-30-2010, 09:59 AM
alan2000T/A's Avatar
i had the same exact thing...and traced to to the wheel spacers i was using.
Quick Reply: cravy viberaton at 95mph
