heater hose problem
heater hose problem
Well I busted a heater hose on my header. burned right through the sleeve I put over it. Has anyone upgraded to stainless braided line for heater hose? What's involved? Will it not burn and bust when it touches the header? Thanks.
Okay I took some pics so you can get a better idea.
First pic is the heater hoses at the heater core. I cut them off and then in the second pic you can see I double clamped a 3/4" heater hose over the 5/8" upper heater hose outlet and then in the third pic i clamped down the other side of the 3/4" heater hose over the lower heater hose outlet.
What I am trying to get at here, is if I took some stainless braided heater hoses, would it matter if they touched the header? There is no room over there and I am already rolling the dice with some of the wires for the O2 sensor and other crap (using some summit heat shield over the wires and there's hardly 1/4" in between the primary and the sleeve - it's going to burn off soon I bet. Probably should wrap the primary that it rubs on with header wrap?
