My speedo and odometer arent working!!!!!!
Old 10-07-2010, 08:43 PM
jdway93z28's Avatar
Default My speedo and odometer arent working!!!!!!
when i turn on the key the speedo powers on but when i drive i get nothin. could it be the vss? i dont have any codes showing up. car has a4 700r4.
Old 10-07-2010, 08:55 PM
ale76051's Avatar
When mine acts up all I have to do it shake the sensor wires at the tranny, so it might work for you
Old 10-07-2010, 08:56 PM
ale76051's Avatar
Or unplug and replug it
Old 10-07-2010, 09:44 PM
jdway93z28's Avatar
ok thanks ill try.
Old 10-07-2010, 10:11 PM
Counted Out's Avatar
Just had this problem.
Check and see if your system is flashing any diagnostic codes. If it isn't, then you just need to replace the VSS pigtail. On mine, the black wire had rotted away from the connector. Your connector may have just came loose though. It's an easy fix either way.
Old 10-08-2010, 07:59 AM
jdway93z28's Avatar
no it wasnt flashing any codes. ima go look under it today
