times for the new 355 with 21* heads
Old 10-11-2010, 02:10 PM
TravisMcGill2000's Avatar
Default times for the new 355 with 21* heads
Went to the local 1/8 milw track.. This is the 1st time out with the new motor. She went 7.43@97 with 1.60 60ft.. The track prep was crap and couldnt hook up all day.. I think at a better track she will go 7.2s
Old 10-11-2010, 02:17 PM
the da was 2800ft
Old 10-11-2010, 02:29 PM
marc97taws6's Avatar
Sounds like she is running damn strong! Congrats!
I know how you feel, Cedar Falls this weekend wasn't even prepped at all......
Old 10-11-2010, 02:55 PM
355z28's Avatar
That thing should really scream in the 1/4. for what your 60ft is its really picking up huge on the bigend of the track. your mph is crazy, especially considering the DA.
My car runs 7.30@93.5 on a 1.6-1.63 60ft with 2000-2500DA. Id like do see what it will do in the 1/4.
Old 10-11-2010, 03:20 PM
BLWNLT1_T/A's Avatar
yea but if you hook, would mph drop a little... Damn good time by the way.
Old 10-11-2010, 03:43 PM
thanks guys. Still got some bugs to work out on it.. Im wantin high 1.4 to low 1.5 60fts. gona take little more wieght out and try it again friday nite at a better track
Old 10-11-2010, 04:14 PM
zigroid's Avatar
what was your bolton/n20 8th mile et/mph/DA on the 11.2 @ 120 run? you running about 2-3 tenths off your nitrous times before in the 8th? thats still pretty damn good.
Old 10-11-2010, 06:11 PM
katz_2003's Avatar
Nice time man!
Old 10-12-2010, 02:38 AM
JoeliusZ28's Avatar
what would that be in the 1/4? Im interested in these heads but ive never paid attention to 1/8th miles
Old 10-12-2010, 06:29 AM
STOCKTA's Avatar
That is great makes me happy I bought into the 21* heads, you think the ported intake picked it up any over your stock intake? Also did you see the results from ported to epoxy/ported intake that Stealthformula ran after the manifold swap?
Old 10-12-2010, 07:53 AM
FASTFATBOY's Avatar
Its making some steam to run 97 MPH in the 1/8 mile.
Old 10-12-2010, 09:21 AM
T/ALT1's Avatar
The car should have run 11.50's-11.60's in the 1/4mile, on a 7.43 1/8th mile pass b/c a few years back when I had LE1heads/cam setup my car ran consistant 7.30's-7.40's on motor and ran consistant 11.50's. I was only running 3.42 gears and the car was a little heavier. Goodluck Later
Old 10-12-2010, 12:08 PM
i ran 7.13@96 with 150 shot and bolt ons.. it was with neg. da also.
Old 10-12-2010, 12:10 PM
Yea i do. I retuned my car after the intake and tb. It made the same power as b4 but i added a 9in ford rearend also.. So im thinkin it gained 10rwhp or so.
Old 10-12-2010, 12:13 PM
It b around 11.5 to 11.6. Im hopin for 11.2s with better da and 60ft.. Still gota little adj. on susp to do.
Old 10-12-2010, 12:17 PM
STOCKTA's Avatar
Thats awesome every little bit helps and your car is running hard for whats in it. 97MPH in the 1/8th is unreal for out of the box heads, Im just going to touch up my 21's ditch my vic jr and port a super vic to match them. I have been waiting for your track times since I want to build a mild 355 short block like yours, I already have a custom built pro-systems carb to compliment everything.
Josh
Old 10-12-2010, 12:23 PM
96lt1m6's Avatar
You have her haulin
Old 10-12-2010, 01:18 PM
joelster's Avatar
It will be quicker than that. If you ran a 7.43 at 92-93mph, then it would fall right in line with an 11.50-.60. You ran 97mph which is VERY good for that ET. Assuming you get out of the hole the same, and then have a top-end charge like you did on that 1/8th pass, you'll be looking at some solid 11.3/4's.
Old 10-12-2010, 01:30 PM
stumprrp's Avatar
cars running GOOD man, i only did 94 in the eight with a 396 and a non-cooperating 4l60 haha.
i think you have a shot at 9s on the jug
Old 10-12-2010, 02:50 PM
JoeliusZ28's Avatar
any videos of this setup?
