Water pump coupler
Old 10-11-2010, 02:19 PM
crazyls1's Avatar
Default Water pump coupler
I was replacing the water pump on my 96 ws6 and accidentally lost the coupler that connects the driven gear to the water pump. Does anyone know if this only goes on one way? The reason I ask is that on end has a groove near the end of the shaft. I just need to know which way this is supposed to be installed.
Old 10-11-2010, 02:30 PM
wrd1972's Avatar
I was told the groove goes toward the timing cover. Thats the way I have always done it and my water pump still turns.
Old 10-11-2010, 02:42 PM
crazyls1's Avatar
Thanks, I have it on backwards and my water pump drive seal is now leaking horribly. Thanks for the info!
Old 10-11-2010, 04:09 PM
shbox's Avatar
http://shbox.com/ci/water_pump.jpg
If you changed the seal, it is very easy to mess up and you might need to redo it.
http://www.impalasuperstore.com/nais...TOPIC_ID=30984
Quick Reply: Water pump coupler
