Missing at high rmps need help
I have a lt1 i have change the plugs and wires and and put the 6 inch boots on in of wires for heat reason the last set was touching headers so my problem is at 5000 rpms to rev limiter its missing but i havent changed out the opti is the opti whole distiputer or just cap and bug or should i change it all and also i did a fuel psi check som1 said it could be my fuel pump but which it is not so if some1 could give me some feed back on my questiong would be really great thanks alot
