Lt1 surging at idle
Old 10-15-2010, 06:57 PM
FBGSU02's Avatar
Default Lt1 surging at idle
its a 94 z28 with intake exhaust only. The car runs perfect driving down the road, no hesitations. But when come to a stop the car will run fine then at about every 20 seconds or so the car will go to 500 rpms and up and surge and then go back to normal still running a little rough. Then at times it can be surging and then go back to noraml and it does it about every 20 seconds. I replaced the IAC and that kept the car from shutting off like it did before. It now catches itself as i mentioned before. so any suggestions????
Old 10-15-2010, 07:03 PM
LSWHO's Avatar
could be a misfire.
Old 10-15-2010, 07:06 PM
FBGSU02's Avatar
misfire? just at idle and be perfect while driving.
Old 10-15-2010, 07:17 PM
droccm98's Avatar
thats how mine is right now, runs seemingly fine driving. but at idle it does about the same. ses light comes on after a while, pulled a code real quick. random misfires.
Old 10-15-2010, 07:25 PM
FBGSU02's Avatar
i did just replace the water pump.... is it the dreadful opti and how do i check?
Old 10-15-2010, 07:32 PM
LSWHO's Avatar
Yup. Mine's doing cyl 4 and 8. hasn't tripped the SES light, but they are there. Keeps my converter from locking 1/2 the time... which is how I figured it out so quickly.
Old 10-15-2010, 07:33 PM
LSWHO's Avatar
Take it apart and make sure it's dry. It may just be wet... or bad.
Old 10-15-2010, 07:39 PM
bowtiedad_z28's Avatar
Did you reset the new IAC after you put it in?
Old 10-15-2010, 07:57 PM
FBGSU02's Avatar
Reset IAC? Nope tell me more.
Old 10-15-2010, 08:59 PM
FBGSU02's Avatar
Could it be an EGR problem?
Old 10-16-2010, 01:15 PM
Bullit95T/A's Avatar
Sounds like a vacuum Leak check all your hoses......
Old 10-19-2010, 10:58 PM
FBGSU02's Avatar
checked vacuum hoses and is good as far as i could tell.... the car will idlefine the drop to 600rpm catch itself, SES light comes on and car runs fine, then when i drive it the light goes off and the car does ok, then if i come to a stop and sit there for a few it will do it again... could this be a bad EGR??? at WOT the car does miss a little, but pulls fine through mid-range
Old 10-20-2010, 06:52 AM
RamAir95TA's Avatar
If you have an SES light, there's no use in speculating - have it scanned!
Quick Reply: Lt1 surging at idle
