High Idle problem (with video)
SES is for:
P0430 bank 2 (passenger cat?)
P0137 bank 1 sensor 2 (rear driver O2?)
P1441 (HVAC?)
I also have an exhaust leak on the drivers side that is starting to get pretty bad
P1441 (HVAC?)
Been there plenty, but thanks....I guess
Took the vacuum off the valve cover that goes to the throttle body and the idle went down to bout normal....no idea why it would do that
did you mess with or remove your PCV lately? lets say you capped it off and left that tube from the valve cover to the TB you would be experiencing a vacuum leak. if thats the case just run a breather on the valve cover.
Test the TPS sensor, That sensor is capable of alot of strange **** when it goes bad..Mine idle'd at 1500 and when driving under very very little load when it shifted it would chirp the tires hahah. Crazy stuff
I think I am having about this same issue. Motor just idles down slowly sometimes or not at all. Was thinking its the maf sensor cause if I tap on it, it comes down quick.
