Need a cam
Need a cam
Im getting my lt1 freshend up and I'm looking for a good low to mid range cam for my b-body it pretty much stock it has 373 gears and a 2800 stall I'm keeping the heads stock(it has crane factory replacement springs)
I need to know if I'm gunna need the computer retuned also
Also need to know were to buy the cam
Crane 227 cam. Awesome street cam with a ton of torque at any rpm.
http://www.summitracing.com/parts/CRN-104227/
That Crane 227 will be a good match for a stockish exhaust setup that needs extra help on exhaust duration. With CAI and shorties/freed up exhaust a Comp XE 502 or even 501 with tighter duration might be better suited. The Comp XFI grinds are going to be too much lift for a stock style replacement spring, so those are off the table. Stock springs only get lifted .447/.459 on the stock cam and start to approach bind at around .490. If you'd be willing to entertain beefier springs, you could have many more options. My .02.
http://www.summitracing.com/parts/CCA-07-501-8/
http://www.summitracing.com/parts/CCA-07-502-8/
I think these would be better because I do have spintecs and a cai
This I my first car and cam swap so thanks for the help
As far as the tune you would greatly benefit from a tune even with just boltons.
Ai also has their version of that cam as well.
Ai 208 / 226 - .525/.540 - 112 LSA Primary Operating Range: 1500-5800rpm
This is an excellent daily cam for heavy automatic cars. Mild idle, excellent drivability, and strong low end through mid-range with peak power at approximately 5800rpm. Properly tuned w/ supporting modifications, M6's typically produce 320-330rwhp SAE corrected.
I could see it working well with supporting mods, as per your own experience. I think you still might have lost some power from the combustion charge into the primaries, but that's a good trap with your old non-optimal setup. Just curious where you were shifting if you recall. Regardless, OP will need to grab some springs and rockers to run even the 227. Amen to the tune, whatever cam & train solution is chosen...
You can call CompCams, Lunati, AI, Golen, JEGS, SummitRacing, etc., etc., directly and order a cam. Make GOOGLE and BING your friends and you'll find lots of companies that sell cams. Comp says one of the worse things you can do is let your friends pick your cam for you.
Comp also makes it clear that most of their lobes, like the XFI and even XEs as examples, were NOT designed to work with OEM valve train parts. Stock valve train parts are marginal at best even for stock use. So if you want to run with the Big Dogs, be prepared to Man Up and buy all the recommended associated parts.
Those are cutting edge, aggressive lobes so if you plan on running them be prepared to go the whole route. It's more than just buying the cam if you want a reliable valve train. My best advice is to buy all the parts that are recommended to work with a specific cam. No corner cutting.
Too often, guys will buy the cam, but Cheap-Out when it comes to buying the right springs and end up buying cheaper springs that are advertised as being "just as good". Then they want to reuse their stock retainers and locks; don't move to Non-Self Aligning full roller rocker arms and even post asking if their stock pushrods can be used.
After varying lengths of time, the failure posts begin to surface on the many Forums. Sprinkled in are posts like "I've been using such and such for so and so long without any problem"; a testament to doing things the not-recommended, wrong way.
Just my views.
Jake
Just my views.
Jake
