Horrible LT1 Problem
Old 10-26-2010, 05:27 PM
ripfirebird94's Avatar
Unhappy Horrible LT1 Problem
Video: stalls while driving and does this. It's a 4l60e. 1994 firebird formula.
http://www.youtube.com/watch?v=xyRJb41qC2A
Old 10-26-2010, 05:38 PM
please i need help asap
Old 10-26-2010, 05:41 PM
please
Old 10-26-2010, 05:54 PM
alexcoreas's Avatar
Check the fuel pressure. Mine did that it was the fuel pump. Check the pressure
BlueRamAir's Avatar
Between your high temp and nonexistent oil pressure I would say you need to rebuild that motor. It may only be head gaskets as it is hard to tell if the oil pressure would be normal if it could hold an idle.
What exactly was going on before it started acting up. The events leading up to this failure may help us diagnose the problem. Is there coolant in the oil?
Old 10-26-2010, 06:13 PM
AmirGTR's Avatar
^ agree with the above posts. Definitely look in your oil see if there's any coolant in it. And the fuel pump for sure, especially since Alex is saying he had the same problem.
I also heard a sucking noise, you sure all the pipes and everything were connected right?
Old 10-26-2010, 06:18 PM
alexcoreas's Avatar
My oil pressure was low as well but after I changed my pump it was all perfect. But first check what the above post said. In my case it was the pump. Hope more people help you
Old 10-26-2010, 06:22 PM
AChotrod's Avatar
Dude sounds and looks like the motor is shot to me.
Old 10-26-2010, 06:30 PM
65panel5.3's Avatar
I would agree with a possible headgasket, the running rough almost sounds like it could be hydraulicing, easiest way is to pull plugs and see if 1 of them is alot cleaner than the other, this would point out a bad head gasket and that the coolant is getting into one of the cylinders, something to try atleast??
Old 10-26-2010, 06:54 PM
No coolant in oil. no oil in coolant. Oil found in throttle body.
Old 10-26-2010, 07:19 PM
AChotrod's Avatar
Its knocking shaking and 0 oil pressure Id check your oil filter for metal
LT1
LT1's Avatar
It also sounds like some of the cylinders are not firing. That's probly why its vibrating.
I can also hear the fuel pump sounding weak when you restarted it.
Old 10-26-2010, 07:26 PM
venom99's Avatar
time to put a ls1 in there
Old 10-26-2010, 07:27 PM
94Z28-MSTGKLR's Avatar
You can have a blown head gasket without any oil in the coolant, or vis versa. Your head gasket could be blown between two, or possibly even three cylinders. I've seen that out come as a result of that before. Either way, sucks to hear and good luck with getting it back on the road.
Old 10-26-2010, 07:29 PM
Damn... I found the IAC connector the plastic part broken off barely connected. So I'm taking out the throttle body out and gonna replace it.
Old 10-26-2010, 07:31 PM
hhow much would an ls1 be to swap in?
Old 10-26-2010, 07:43 PM
alexcoreas's Avatar
Not worth it!!!!!! Ls1 what for put that money on your lt1. Or do w.e u want ls1s aren't immaculate they still have problems **** goes wrong with any motor if u don't maintain it. Hence ls1tech to help with problems key word ls1
Old 10-26-2010, 07:51 PM
TransAm Bandit's Avatar
check ur Fuel Pressure.
R.I.P Lt1
you can get LS1 from 2k to 5k Depends on Millage,
but U need Many Stuff For That Swap
Old 10-26-2010, 07:53 PM
fex77k's Avatar
Whats kind of pressure are you getting at the rails. Are you getting good spark? The oil in the intake is probably coming from the valvecover to TB vent.
Old 10-26-2010, 07:57 PM
^ ls1's have no where near as many issues as a damn lt1.
To the op. If it came down to it and it was a full blown race car, of course it would be worth swapping out for an ls...just about anything. Seems how I'm going to guess its probably your every day car I'm going to say no.
Quick Reply: Horrible LT1 Problem
