HA! New Prob Weird Alternator issue....Wiring guys help
Well i finally fixed my high rpm miss...
installed EFI Connection with a custom built harness
Now I have another weird problem.....
I have not had a belt on the car because no one had the right size in stock... Car runs great without the belt... Here is where it gets weird...
The belt come in the mail today and when I installed it the car will start and the fuel pump dies (I can see the fuel pressure go to zero on my gauge) and the temp gauge goes to max??? Take the belt back off and it runs fine..
so I figure it Has to do something with the alternator charging with the belt on so I decided to unplug the alternator...the car then won't even turn the starter....???
plug the alternator back in and remove the belt and it runs like a champ....
anybody have any good ideas??
Can anyone tell me what the wires under the dash go to? there are 3 pigtails that go inside the car... 1 is flat and has 4 spots but only 3 wires...1 of them is a large purple wire which i believe goes to the starter... the other is black with a white stripe which i assume is a ground and the 3rd is all grey???
