how do i launch at 3k rpm ?? without spinning
any help is needed heres my mod list if it helps
tci 9.5 street fighter torque convertor 3k stall
230/236 112lsa cam/1.6 rockerarms
headers,intake and allot of other small bolt ons
i'm thinking upgrading rotors and put some new brakes as a example
any suggestions are welcomed? thanks
well it tends to want to push but with a little hard pressure on the brake stays still i was using rotors as an example of a upgrade, nitto drags are on the way, any thing else or that will help?
Originally Posted by ram air camaro
(M/T) meaning mickey thompsons? i do allot of drag racing on the street
time for bed.. 151 is hittin me hard now
you will hardly ever see the advertised stall of a converter by footbraking. i have a Pro Yank Extreme 3800 and can only footbrake till about 32-3400 MAX and that is with hoosiers.
if you flash the converter, i.e. get good tires,hold it around 13-1600 and then nail it,it will flash to 3k and hit hard.
