LT1 Alt with Tall Valve Covers
Old 10-30-2010, 09:00 PM
Z28Roxy's Avatar
Default LT1 Alt with Tall Valve Covers
I know you need to grind away part of the alternator:
In particular on that "ear" piece, my alt has the end of a bolt sticking out... Seems like I shouldn't just grind that away but I kind of have to?
Just making sure that's what I need to do...
Old 10-30-2010, 09:14 PM
NewOrleansLT1's Avatar
There are many different tall Valve covers? Which ones are you going with?
Old 10-30-2010, 09:30 PM
Z28Roxy's Avatar
I have these:
(if pic doesn't show up):
http://www.proformparts.com/product-...ategory_id/247
Old 10-30-2010, 10:08 PM
Most people that have those valve covers relocate their alternator.
Old 10-30-2010, 10:46 PM
Z28Roxy's Avatar
Well I don't want to do that...
I plan on running a supercharger and I don't want to ditch my AC or power steering.
Old 10-30-2010, 11:01 PM
robsquikz28's Avatar
My buddy has those and ground the ear off
Old 10-30-2010, 11:26 PM
Z28Roxy's Avatar
What about the end of the bolt that's in the middle of the ear? Just go to town on that ****** too?
Old 10-30-2010, 11:37 PM
He only uses the top and bottom bolt holes. He eliminated that little bracket that holds the alt. to the intake. That bracket is useless anyway IMO
Old 10-30-2010, 11:49 PM
Z28Roxy's Avatar
It's not part of the bracket... but yeah I know you ditch that too.
Old 10-31-2010, 09:09 AM
lt1-xjs's Avatar
I have those and just ground the ear off. Bought them at a Super Chevy show almost 10 years ago.
Old 10-31-2010, 09:37 AM
jaycenk's Avatar
I use those with every damn bolt and all factory Acc. Tape off any holes into the alt. then grind away the area in the picture in you original post plus a tad off near the bearing. some times you need to take some off near the bearing sometimes you dont. I just ground a little and then test fitted it on the car. if it didn't fit I ground a bit more, and test fit it again. It takes about 15 20min. You are also going to have to grind down one of the regulator bolts flat
Old 10-31-2010, 10:25 AM
Heat Seeker WS6's Avatar
Hey Roxy I also yanked that bracket but got notched valve covers, so had no grinding to do.
I re-mounted it to a garage wall now, so it holds shop towels n junk.
Quick Reply: LT1 Alt with Tall Valve Covers
