TB Coolant Bypass
TB Coolant Bypass
Ok my buddy said you can get more power by blocking off the coolant passages within the stock TB? In theory it should keep the throttle body cooler and therefore keeping your incoming air cooler resulting in better power. In reality does this really work or is it not worth doing?
seems like every make of car like to run coolant in this area, why the hell? can see it helpping in any way to have hot coolant and on a cold start it seems like it would take too long like those old exhaust to aircleaner things on older cars
It's not for fuel economy. It's to keep the throttle blades from icing during extended operation in extremely cold climates. No one has ever reported a problem after bypassing the coolant hoses.
