93/94 swap hard start.
Old 11-07-2010, 05:24 AM
mattcossel29's Avatar
Default 93/94 swap hard start.
I just finished up swapping the 94 4l60e/harness/computer/etc.. into my 93 formy.
I am having problems with it starting. When I go to start it I let the fuel pump build pressure then I crank the engine, the engine cranks for a little while. I am peddling the throttle slightly it will not even fire if I do not do this.
Related info:
- I do have a cel, but have not pulled the code
- The pcm is tuned for this setup(mostly anyways)
- I am running a 93 throttle body
- Once it fires and runs it runs very good
Oh, I tried switching to a later year throttle body and it would fire quick and easy but it would rev to about 2 grand for a second then die.
If I revved it on startup sometimes it would try to idle but usually failed. IAC problem?
If you have any suggeestions or help I would really appreciate it.
Thanks!
Old 11-07-2010, 05:02 PM
ttt
Old 11-07-2010, 05:15 PM
curacaoz28's Avatar
I think the problem is not related with your swap, u should check you tps voltage.
check this link: http://www.lt1swap.com/93lt1a4.htm
Old 11-07-2010, 05:36 PM
robsquikz28's Avatar
Problem 1
Old 11-07-2010, 07:37 PM
Problem 1
I was told that the IAC was different in the 93 tb to the 94+.. I just kept it on because its the one I know it will run on. Like I mentioned I did try a 94+ tb and it would start, but rev to about 2 grand and then die.
Old 11-07-2010, 11:05 PM
RamAir95TA's Avatar
There is absolutely no use speculating until you pull the codes.
And what does "mostly anyway" mean in regard to the tune?
Old 11-08-2010, 12:32 AM
Well.. it is a canned tune from pcm4less, I had to scale the injectors down for my stockers that are in it for now. It was tuned for 44lb injectors...
Also it is tuned for a 52mm aftermarket throttle body and I am using oem ones to test.
Other than that it is tuned for the 306 cam in a similar setup.
Hopefully I can wake up in time to go fix the brakes and put the exhaust on it so I can take it to oriellys and pull the codes.
Old 11-08-2010, 06:54 PM
NewOrleansLT1's Avatar
You need the stock tune back in it pal...
Old 11-08-2010, 07:06 PM
Heat Seeker WS6's Avatar
Neutral safety switch? Just an idea.......
Old 11-08-2010, 11:02 PM
1badzee's Avatar
You need the 94+ IAC+housing. I did this swap a while ago and it was straight forward. Sounds like you need a tune more than anything.
Old 11-09-2010, 01:51 AM
Dont have it
I have one in it now.. Its better but it still starts hard. It started great and idled great for a while but now its starting hard.. It idles decent though.. I need to have it tuned and try another IAC possibly.
Old 11-09-2010, 07:55 AM
RogueLT1's Avatar
a dealer could put it back to the stock tune, I would think. I'd agree with NewOrleans on this one: you need a stock tune for a stock car.
Old 11-09-2010, 08:15 AM
RamAir95TA's Avatar
You are chasing a problem that you likely created yourself. You need a stock tune.
Old 11-14-2010, 03:55 AM
But.. its not stock.. it just has stock injectors. It has the cc306, -5cc pistons, 2.02/1.60s with slightly worked over heads and IM.
I may have found the issue. I fixed a few vacuum leaks and fired it up with freescan and noticed the coolant temp sensor is not readimg.
Oh and I switched the tb out for one off of a 96
Old 11-18-2010, 08:28 AM
The vacuum leak was causing the revving then dying and the coolant sensor caused the hard start. I also had a bad plug wire. Fixed these issues and it runs great!
Quick Reply: 93/94 swap hard start.
