Worn throttle cable? Or Wtf?
I was setting the TV cable on my 93 z28 the other day when I noticed that when the gas peddle is pushed all the way down, the throttle blades were only about 3/4 of the way open. I mashed the peddle down pretty damn hard and the throttle blades finally went all the way, but it takes a lot of effort to press the peddle down that far and hard.
Is there any kind of adjustment I can make to the cable, or is it just worn out? Time for a new one?
There is no adjustment on the throttle cable..sounds like its time for a new one,its most likely fraid inside the plastic coating.If you need one I have one from a low mileage z28 without traction control.
