motor build questions?
Ok guys i have a 97 z28 A4. I just had a rod bearing go so im pulling the motor and will be rebuilding the bottom end and hopefully doing h/c as well. I will be rebuiling the bottom end using ground stock crank, forged i beams, and a set of forged flat top speed pro pistons. Since the car is an A4 there are very few cams i can run without replacing the converter. The car is currently bone stock but i plan on getting a CAI and headers. Would the car be able to handle a high stall converter on a mild cam. Im afraid it wont but i eventually plan on running the ss3600 when i get my heads and cam and i really dont want to have to buy 2 converters. The car is also getting a new water pump, opti, oil pump, lifters, etc.... Would the spider need replaced?
Nice im going to order my ss3600 once i get some birthday money. Im pretty excited to know that i can run that converter on my bolt setup for a while. Well i will definitely be getting a cam then when i do my motor. Would i be able to run stock gears for a while too? I plan on eventually swapping to a midwest 9" with a truetrac.
