What scanner are you OBD II guys using?
Old 11-17-2010, 03:15 PM
jaycenk's Avatar
Default What scanner are you OBD II guys using?
What scanners and what features should I be looking for. I have SEL and need to find out why but I am not driving to autozone every time so which ones work good for ya?
Old 11-17-2010, 03:18 PM
LSWHO's Avatar
I have used an LS1m from my GTP days. Works well but doesn't do enhanced parameters on LT1s strangely. It does on LS1s and L67s tho.
I don't think Mark makes them anymore tho.
Wow. Can't believe I remembered his name. I used to do some beta testing for him. LS1m.com You may be able to find the cable somewhere or make one and just download the software to a palm or emulator on PC.
Old 11-17-2010, 04:02 PM
jaycenk's Avatar
Ok well anyone else? simple question here.
Old 11-17-2010, 04:04 PM
LSWHO's Avatar
I've searched multiple times for OBD2 scanners/dataloggers. Nobody can give an answer. And google is of no help. It makes you wonder how these OBD2 people are doing it. It seems like the only answer is autotap or similar. I believe they are also using efilive?
Old 11-17-2010, 04:17 PM
jaycenk's Avatar
Well thats where I am at this time I have a custom set up and I can't figure out if I should just buy a scanner or buy software and cable for it. Problem is searching isn't a help because the cables I find say they are OBD 2 connector but only work on OBD 1 systems lol. Anyone have an answer to this???? I know I have asked before and gotten 0 responses but I know there are guys on here running OBD 2 setups.
Old 11-17-2010, 04:34 PM
LSWHO's Avatar
I hate to tell you man, but I pretty much already gave you the answer. Autotap or similar for scanning/datalogging and JET DST or lt1 edit
...OR switch to OBD1 and get the software much cheaper.
Old 11-17-2010, 07:19 PM
old93camaro's Avatar
look here i use these at the job
http://www.amazon.com/Equus-3100-Inn...0043069&sr=8-8
Old 11-17-2010, 07:27 PM
robsquikz28's Avatar
genesis scanner
Old 11-17-2010, 07:35 PM
chevymec's Avatar
Originally Posted by robsquikz28
genesis scanner
x2. I used a Tech 2 for about 10 years and this thing is almost as good.
Old 11-17-2010, 10:20 PM
jaycenk's Avatar
Wow thats a bit more than I was really looking for but way freakin cool. I have been looking at this http://www.google.com/products/catal...CBYQ8wIwATgA#p
Not sure if I want to do this or just buy a tuning kit.
Old 11-18-2010, 09:05 AM
96LT1355Z28's Avatar
I take this on with me to the track. It doesn't show everything but for the $ isn't bad. Plus it will show live data and logs up to 60 seconds of selected parameters in 1 second increments.
http://www.harborfreight.com/can-obd...ner-98614.html
For the house I have access to a Snap-On scanner that reads everything.
Quick Reply: What scanner are you OBD II guys using?
