Hard to start my car, in cold and hot conditions.
Old 11-19-2010, 03:29 PM
LT1559's Avatar
Default Hard to start my car, in cold and hot conditions.
So it takes about 10 seconds for my car to start up. for the first second i turn the key it sounds like it's about to start, then it starts cranking like the icm is unplugged or something...then after about 10 seconds of cranking it'll start, but the rpm's will shoot up to about 2k, but will drop down back to normal idling after about a minute or two, and the K&N cold air intake i have starts to get really loud. the car drives okay but it kinda feels like i have a missfire. I don't get any codes. i changed the plugs and wires, changed the intake manifold gaskets along with the throttle body gasket about 2 months ago. any ideas? and my car goes through gas like crazy even under conservative driving conditions.
Old 11-19-2010, 04:08 PM
Gojira94's Avatar
Originally Posted by LT1559
...and my car goes through gas like crazy even under conservative driving conditions.
Stuck injector, or more likely, blown diaphragm in the fuel pressure regulator. Follow the vacuum line that goes from the regulator to the intake and pull it off at the intake (pass. side, above the A/C vacuum valve line, behind the purge solenoid). If you've got fuel coming out that vacuum line at KOEO (key on engine off), replace the regulator. It's a little bit of a pain to get to if you have to replace it. Don't lose the o-ring on the fuel return line or the regulator body while you're swapping it.
Old 11-19-2010, 06:17 PM
LT1559's Avatar
would that also cause a missfire?
Old 11-19-2010, 06:26 PM
Gojira94's Avatar
similar symptom- no gas, no fire.
Then again, you might have a lingering companion issue in secondary ignition that isn't helping matters. As far as your intake getting "really loud" is it a whistling sound? Check the FPR, check for vacuum leaks first and go from there.
Old 11-19-2010, 06:44 PM
LT1559's Avatar
it's like a vaccum sucking loud...i thought it was cause the rpm's going up to 2k, but then when its idling and i step on the gas up to 2k it doesn't get loud like how it does when i described it.
Old 11-22-2010, 04:57 PM
LT1559's Avatar
anyone else have any input? I left the car sitting for 3 days, then this morning i went to start it and it started with no hesitation. But when i got to my office I turned it off and tried to start it again, then it did what i explained in the original post :/
Old 11-22-2010, 06:38 PM
lt1slowz28's Avatar
check the fuel pressure, the pump might be on it's way out.
vacuum leak?
TPS?
maybe a bad ground somewhere?
Old 11-22-2010, 06:52 PM
LT1559's Avatar
i still haven't tried to pull the vacuum line to test the diaphragm.
how do i test the tps? and would anyone happen to know where i can find a diagram for all of the grounds? i'm for sure getting a short circuit somewhere cause the fuse for my turn signals go out in less than a minute of replacing them.
Old 11-22-2010, 06:56 PM
lt1slowz28's Avatar
www.shbox.com for all your woes.
he has everything you could possibly need, if it doesn't you should probably pay somebody by then.
Old 11-22-2010, 06:58 PM
LT1559's Avatar
damn how could i forget to check shbox. thanks
Old 12-07-2010, 07:22 PM
LT1559's Avatar
sorry, should've kept everyone updated. but yeah i checked that vacuum line to the fpr and no gas came out so i dont think it's a blown diaphragm...but for the past few weeks i noticed that EVERYtime i would go to the gas station and pump fresh fuel i would have no hesitation in starting the car whatsoever on the initial start up after i've pumped. but if i drive for about 10 minutes and turn it off and try to start again it'll just crank and crank for a few seconds then start
Old 12-07-2010, 07:23 PM
RamAir95TA's Avatar
Have you done a fuel pressure test yet? You can pick up a gauge from most any parts store for around $35.
Old 12-07-2010, 07:27 PM
LT1559's Avatar
Not yet, but i will. i know that i've been needing one for a while now since i've read up a lot about all of the missfires people have been having
Old 12-07-2010, 08:19 PM
RogueLT1's Avatar
vacuum leak?
TPS?
Man, I feel like this is the only comment I ever make to people. But, I agree here. Check the fuel pressure. could be a bad pump.
Old 12-09-2010, 02:31 PM
LT1559's Avatar
lol thanks, i will for sure.
Old 12-29-2010, 01:50 PM
LT1559's Avatar
Bringing up an old thread, but just if anyone was curious of what the problem was, it was the fuel pressure regulator...thanks for the input everyone. my car now starts up fine. hope this helps anyone else who might've had this trouble. oh and i forgot to mention that in the process of changing the fpr, i noticed that when i disassembled the intake elbow, that tube that connects underneath it had gasoline built up in it...i was wondering if the fpr could've had something to do with this?
Old 01-06-2011, 02:30 AM
1Psycho's Avatar
Where'd you buy the regulator from and how much was it? Mine's startin to do the same thing where it cranks for a few seconds before actually starting :/
Old 01-07-2011, 10:00 AM
LT1559's Avatar
autozone, but i would go to a junk yard lol, i just felt lazy so i went to autozone and forked out $80
Quick Reply: Hard to start my car, in cold and hot conditions.
