Lt1 Rockers
Old 11-19-2010, 07:53 PM
Choppers's Avatar
Default Lt1 Rockers
Will these rockers work on a 96 lt1? I found someone with them but the part number isn't the usual one everyone uses.
http://www.summitracing.com/parts/CCA-1305-16/
Old 11-19-2010, 07:59 PM
ElkySS's Avatar
yes but u will need new rocker studs in 7/16
Old 11-19-2010, 10:41 PM
suicidal racing's Avatar
i have nsa 1.5 mags in 3/8th for sale 125$
Old 11-19-2010, 11:19 PM
Choppers's Avatar
I want 1.6. Thanks though. Will any ARP 7/16' stud work with those?
Old 11-20-2010, 09:56 AM
MattSapp95_T/A's Avatar
sent you a pm
Old 11-20-2010, 12:33 PM
Choppers's Avatar
Originally Posted by MattSapp95_T/A
sent you a pm
And I sent one back.
Old 11-20-2010, 01:07 PM
RsSean's Avatar
Are 7/16 stock rocker bolt size? Or will the rocker bolt holes have to be drilled and tapped to adapt to the 7/16th stud?
Old 11-20-2010, 01:10 PM
am_muscl's Avatar
usually the bottom part of the stud should be the stock size. the only difference would be the top thread size. At least that's how mine worked. and I have those same rocker arms and they are badass.
Old 11-20-2010, 01:51 PM
RsSean's Avatar
Ok I was hoping that would be the way it would be, cause drilling and tapping heads with Helicoils for some rockers would be nuts
Old 11-21-2010, 09:09 PM
JAKEJR's Avatar
No drilling, tapping or adapting needed. The 7/16" studs screw right in and are torqued in place. I use anti-seize on the threads of the studs that screw into the heads.
Studs canm be bought in different lengths. I chose the ARPs that are longer than stock to give the poly-locks more thread engagement. IIRC 1.90" Pro Series.
Check SUMMIT's site for the different ones available.
Jake
Quick Reply: Lt1 Rockers
